Anyone else having to fiddle with the key several times and even lock/unlock the car to get it to start? It began doing this last month, now becoming more frequent. Asking for the clutch to be depressed while it already is.
Thx
its the switch, hapend to me and many others, simple job, same day if they have them in stock, as for the passenger window, they cant change that ul have to get use to it
I have the same problem, are you saying it's the ignition switch in the dash that needs replacing. I thought it was a bad starter, it helped when I rocked the car a bit.
