Changing transmission oil
#31
And thanks for the guidance on the washer. Took it for a test drive and it looks dry as can be, but I'll keep watch for any leaks.
#32
yah It is there for a reason, to a degree. Like you said just keep an eye on that.
I am a mechanic but Im a total tard with porsches. I am brand new all over again
#33
Couple of years ago, Enthusiast did a writeup.
https://rennlist.com/forums/gt2-and-...ferential.html
900.123.118.30 ----- sealing ring, aluminum (need two)
In my DIY I did point out that you must loosen and remove the filler plug first so that you don't get yourself in a predicament.
I have the Mobilube PTX and have shipped some to Rennlisters. Send me a PM for the details.
#34
I use the alum crush washers on both the drain and fill plugs. I also replaced the fill with a male 19mm plug which makes its VERY EASY to r&r. It's a <$10 part at your local Porsche dealer. Part no. 90012402001
#35
We were just about to Post up this question, but figured to check through all the posts, just in case.
We had a customer asking for one of these, but couldn't find the P.N.
Thanks Del.
#38
#39
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#40
Basic Sponsor
Good thread/info folks!
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
#41
People still recommend the Delvac?
What is the real tool to use to loosen the fill plug? Disassembling a 10mm hex socket and putting a wrench on it (per the original DIY) isn't my speed, want to buy the correct single purpose tool
#43
I used Mobilube since I wanted the factory fill.
Tool: I used a normal L shaped hex bit. It was a little tight so I shortened it a bit. Pro tip to get more leverage: slide a 10mm socket (with a breaker bar or whatever attached to it) over the hex bit.
#45
Yup, I only use Delvac. For my 6GT3, 7GT3, and 6TT. When Copans said to only use Delvac on my Mezger boxes, I haven't used anything since then. The part number for the replacement insert I'll have to check later when I have access to my "book".
With that said, I use the Shell factory stuff in my wife's CAB.
