4.0 exhaust options and sound
it will be here shortly and I plan to install either a SW or GMG bypass. Both vendors tell me installation is the same as 3.8. Does anyone have any firsthand experience with the 4.0 and bypass options ? is the stock 4.0 setup (with titanium Akrapovic muffler) noticeably different in sound than the stock 3.8 ? The car should come with titanium tips which would bolt straight onto a SW bypass. Thanks for any input.
Received 1,839 Likes
Higher flow cats, larger displacement, and higher flow airbox should yield a slightly different sound - my guess a bit deeper with more intake noise. I wouldn't waste money on center exhaust swap - little to gain and will detract from originality of car. If you're after real HP gains it'll require a full system upgrade.
Have there been differences noted between the 3.8 RS and the 4.0 RS exhaust? I thought both were produced by Akrapovic. If that is the case go ahead and get the the Sharkwerks, the sound improvement is well documented here.
Also, for all those saying the 4.0 is going to be a collectors item in the short term, everyone needs to get real. These cars are not going to hold their value (cough GT2 RS), and the exhaust is possibly one of the easiest pieces to return to factory.
Unless the owner plans to own the car for 15+ years this car is only going to decline in value. And given the fact that we are all uber Porsche enthusiasts, i doubt any 4.0 owners are going to be able to deny their desire for a 991 GT3 and even if they do, definitely not a possible 991.2 GT3.
I'll try to get a sound clip for you... it's the same part as the 3.8RS ti exhaust (which btw has been known to crack on the front side before). Going to stainless on our part the whole set up is still 8 pounds lighter so you're not adding weight either. The sound is different but so far I've sent three out to 4.0 owners abroad and need to get a clip
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I'll try to get a sound clip for you... it's the same part as the 3.8RS ti exhaust (which btw has been known to crack on the front side before). Going to stainless on our part the whole set up is still 8 pounds lighter so you're not adding weight either. The sound is different but so far I've sent three out to 4.0 owners abroad and need to get a clip![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Weight of the stock:
Weight of stock RS titanium:
Weight of ours:
So whilst we could "maybe" save another 2.25 pounds off of the 5.5 pound system wight have for the cost involved would it really be worth it? Probably not. Not only is the cost prohibitive but then you get into the problems of movement, heat expansion and cracking which we've seen on these cars over the years already with Ti
The Titanium rear center muffler in the 3.8 RS develops cracks. I know of 2 people with failures, so I would expect the same muffler to developed cracks in the 4.0RS.
However, most 4.0 RS will be ornaments, so the mufflers won't crack in garage storage or trips to Starbucks.
If you want a better sounding 4.0RS Sharky produces awesome sound and no resonance.
