My 4.05L kit for my 7GT3RS
This kit is proven. In fact, it was one of the first big-bore kits developed in so-cal by Wrightwood racing. The first engine built was back in 2003...way before sharkwerks started experimenting with increased displacement. I have not heard of a failure yet.
I'm using the liners from Capricorn as well, except the OP is using 106mm pistons while I'm using 105.4 for exactly 4000cc displacement. Good luck with the build!![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Silverboy: this is definitely an interesting route. Being in HKG i have the same problem--Sharkey is too far away yet I'm skeptical of trusting the local guys to something akin to open-heart surgery. I'll be closely following your build!
So to clarify, the stroke of your rebuild remains the same while the bore goes up by way of thinner liners. Are there modifications to the block itself? How are you doing the ECU reprogramming?
You and I are in equally hot climate so it'll be interesting to see how you deal with longevity/reliability issues.
p.s. were you at Sepang last weekend when PCHK & PCS took out the track?
- Latest 997 cup heads from PMNA, ported 996 intakes to match, 997 throttle body and intake plenum ported to match.
- Exhaust is 997 header/cats and 08-10 997 cup muffler. If it wasn't a street car, we would do something more exotic.
In a nutshell, we are taking advantage of the engine refinements in the 997 series.
I would love to retrofit some of the RS 4.0 intake parts, but the cost/benefit ratio becomes high with many other additional parts that would also need to be swapped.
To help the car breathe, we're doing:
I didn't realize you were going to keep this thing running emissions (hardware and software) ... that's impressive. That's one of the most impressive things about the SW 3.9. I've only driven it on the street, but it's so well-mannered, sucks down 91, smog's, burbles along in 3rd gear at 2500 rpm and not so much as a single spark goes astray when you want throttle response or just a hint of smooth acceleration.
Looking at the parts prices for the 4.0, it looks to me like Porsche is deliberately saying "sure, you can buy our hot rod parts, but you'll pay a pretty penny for our R&D." It still boggles the mind, ever since the 996 GT3 of '04 to imagine these high revving 400+/- HP engines with 40K mile factory warranties. Just amazing.
All this talk of torque has me itching to get into the 4.0 RS. There's a car that should come from the factory with a full cage and harnesses mandatory. : )
They showed me how inaccurate the dash water temp gauge is and it continues to measure 90DegC when the temp is a lot higher so many people believe their temps are in the green when in reality power is being sapped.
Does anyone have any source for upgraded radiators (their Oz one was 2500Euro which I though a bit steep) Oakley list some but I have heard not to deal with these people ?
http://www.oakleydesign.eu/aluminium-radiator-kit
SW don't in their 3.9L kit so I am figuring it would be fine.
I don't intend to go out more than 20 minutes per track run.
Also meant to be a street/track car with about 80%/20% split.
RS Tuning fit a special centre radiator to all the race cars and many turbo street cars (the one they use is from an Australian source) and say it is worth real power on the track.
RSR's use PWR radiators as far as I'm aware, well at least they did on the 996 RSR's.
I'm assuming you mean PWR? You could source one directly from them yourself for alot less then that price you have quoted but they are still a ridiculous price for what they are. I recently was looking at replacing all 3 of my radiators with the PWR ones, I live in Australia, but could not justify the cost.
Holy sh*t... you went for it!
This reminds me of the time I told you not to supercharge your other car... and you did anyway!
guys, Silverboy has one of the most serious cases of "mod-itis" I've ever seen.
the upside is, you're taking the plunge on R&D and this thread will surely be epic!
when are you starting the work? Do it AFTER this weekend! join us at the track! (and for the record, I was short shifting your car out there! it just sounded like i wasn't coz its so frickin' loud! John said you sounded concerned hehehe!)
anyway, subscribed!
car will be awesome for sure!
anyway, subscribed!
hehe...had a feeling you will do it...cant wait to see it running but hesperus is right, join us this weekend before you open her up![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I think hesperus is happy you will be doing it because he might follow your road
btw dyno the car before the build
Another thing to note is that they make 2 different versions for porsches. A normal up graded radiator for GT3's & a 24hr version for cup/RSR's etc. I believe the only difference besides the price which again is nuts is the thickness of the core's. I'm not sure which one RS use.
