2010 cup rear bumper
2010 GT3RS Rear Bumper Conversion to Cup Or Other Carbon/Kevlar? Who Has Done It?
Considering options here. Anyone converted a 2010+ GT3RS to Cup carbon/kevlar rear bumper cover/tow hook? Would hugely appreciate any comments as to feasibility without requiring a ton of modifications. Primary objective is weight savings not cosmetics. Thanks!
For the rear towing-hook + spring you will have to completely remove the crash bar.. as the 2010 still uses the 996 cup tow 996.722.693.92. A big no no if you street drive it at all.
Otherwise I guess the weight savings from a US bumper to this would be about 20-30pounds?
Obviously enough, once you remove the rear impact absorbers, any little "love touch" on the track becomes a matter of almost limitless damage (headers pushed off the heads, crushed exhaust, engine carrier crushed into the pulley, etc.)
Yes to install the front and rear PMNA spring loaded tow hook, you need to remove crash bars as they use the same mounting holes.
BUT, You can have both but it requires custom work.
I know of cup cars that have added back the crash bars to prevent tub damage from racing bumps.
I would contact Fabryce at GMG, as I have personally talked with him about this and I know they can make them for you.
DO NOT, I repeat... DO NOT remove the crash bars from your street car just for looks. You will be the one losing out in the end.
Speed Gallery makes both the front and rear 2010 bumpers in a lightweight CF/FG blend. $1,700. front, $1,500 rear. They also make a CF hood for $1,100.
(818) 766-2321
Dan@thespeedgallery.com
(818) 766-2321
