For those with old school wheel bolts, anyone switched to lugs?
#31
Which ones are you using?
This: http://www.race-studs.com/servlet/th...ce-Stud/Detail
Or This: http://www.race-studs.com/servlet/th...Nose%27/Detail
The bullet nose appear to be less expensive... However, they are longer to accommodate the nose.
I should add that I also tried the 65mm race studs and returned them as impossible to hand thread. You have to use a socket, which (to me) defeats the purpose. IIRC, the 81mm bullet nose has the same usable threads as a 65mm race stud.
-td
