997.2 GT3 RS brakes
I probably have about the 1/3 pad left and I'm using the 29s as well and they work fine as long as you tap the pedal up a bit. These pads are crazy thick so even at 1/2 a pad knock back can be a real problem causing a soft low pedal. The pads themselves work fine.
Typically I'll take my pads down to just a little more than the thickness of the backing plate before tossing them.
I am doing the conversion from PCCB to steel. Going to get steel rotoer and run the r29s front and back from what I see here.
Already running SRF and pedal feels great.
Was planning to buy porsche steel rotors, is that what most of you do? Probably running 8 to 10 track days this year. Already got 3 events in this year and its barely april.
yeeeehaaaaaaa
yeeeehaaaaaaa
Save your money and just do a fluid change first. You should have done it before your first DE. Stock fluid is not up to the task, hence why your pedal went soft. No pad change will make up for poor fluid and you will never be able to fully utilize your brakes until good fluid goes in. Stock brake pads are RS-19s and will be more than up to the task once good fluid goes in. I've had no issues running Motul 600 in mine and put 11 track days on stock pads last year before wearing them out. Also keep in mind that the front rotors are not only larger than the older GT3s, so are the calipers and the brake pads. Hence what may have been the best setup on the older cars is not the best setup on these cars.
If you can generate enough heat you can boil any brake fluid. I boiled Motul 660 in my old Carrera. The 997.2 GT3 does have some advantages here. The new 2-piece rotors are more efficient for brake cooling and there are 2 brakes scoops on every corner. One of the biggest surprises I've had with this car is how capable the stock brakes have been at the track, once good fluid was put in. Stock front rotors will crack with heavy track use. I had to replace mine after a year. They rears on the other hand don't have a single crack in them. I would recommend sticking to the stock rear rotors while switching to something else once you wear out your first set of fronts.
I've not flushed or bled out the factory fluid at all -- a year, 1800 miles a dozen track days running Hoosiers and circulating in open passing at a pretty quick clip. I've been running PCCBs but I don't think it's the ceramic or the iron, it's the pad compound.
I'm curious to hear back from various people trying out Endless and some other after-market pads. I think Pagid has lost the plot for this pad and these rotors. No question, Pagid is the benchmark, but in this 997.2, the stock compound and the race "green" are not working.
I'd suggest two easy ways to improve the performance of the equipment:
1. brake in a straight line and trail, don't "crush the pedal into the apex"
2. clean out the cross bores in the rotors between sessions.
Just remember to wear a mask and eye protection. And let the rotors cool to ambient before blasting with compressed air. An alternative is a small Allen Key. Either way, roll the car forward a half wheel rotation to expose the rotor from inside the caliper.
This has been discussed on various threads, but after my first DE, I was a little disappointed with the stock (non-PCCB) brakes on the car. The pedal feel went from hard to mushy in the course of the day, but I am not sure that it really affected performance (the "bite" was not very impressive). I am switching over to Pagid Yellow 29s in front and Black 14s rear, along with a fluid change to Motul.
another strange thing i noticed.
if i am alone, i use motiv to bleed.
if i have a helper, i have use two ppl method with one pumping the pedal.
the two ppl method always provides a firmer pedal. i dont know why, but it is very consistent on every car i have had.
some argue this method will blow out the master cylinder, i haven't. and if it does so be it as long as i have a good pedal feel until then.
For a bleeding, you should never pump the pedal in these cars. They are designed to only be bled at high pressure due to the reverse flow in the master cylinder from the ABS system. You can damage the seals using the pedal method. Just use a power bleeder. Then when driving the car the first time following, make sure you get the ABS to engage a couple of times. This will flush the master cylinder and release any air inside of it.
Basic Sponsor
Gentlemen
I highly recommend considering the Endless fluid they are factory fill on the cup cars, RS hyrbid and factory approved by Porsche Motorsport.
Endless is also the only other company that makes a PCCB compatible pad that is track oriented.
In terms of replacement rotors, I would also recommend going with the Stoptech DRK if you are not planning to replace the calipers themselves
We have personal experiance with the Endless pads and brake fluids as well as with the Stoptech rotors..
Bottom line they work..
The brake fluid has a higher boiling point than SRF and is more consistent.
The pads well there really is no comparison to the Endless pads...
If you need more info please feel free to drop me a line.
We have pads, fluids and rotors in stock for all 996 gt3, gt3, 997 gt3, rs and gt2 cars with either iron or pccb rotors.
Here is a little video of how well they work![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
http://www.youtube.com/watch?v=QGhZVGDGh6c
![](https://rennlist.com/forums/signaturepics/sigpic29347_6.gif)
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
sales@gmgracing.com
www.gmgracing.com
714.432.1582
Hi Fabryce,
I see that StopTech also makes a DRK for the 6GT3 PCCB replacement. However due to the hat design, one needs to modify the pads to clear the hat. How difficult is it to modify the pads??
Basic Sponsor
Modifying the pad is easy and we can supply pre cut pads if needed.
You are removing approx 5mm of material from the inner annulus of the pad..
Feel free to drop me an email for a price quote.
Happy to help out I have this set up on my 996 GT2 and LOVE IT!!!!
Replacement of rotors is very cost effective as well ....
I've been thinking of using the quick bleeder nipples -- has anyone tried those things (never too confident about putting a valve right where it would be just unpleasant if the gadget failed.)
I wonder if the pressure on the master from the pedal and the action of evacuating the master cylinder with the piston (instead of just blowing fluid through with the powerbleeder) is leaving residual material/moisture or even air dispersed or dissolved in the system.
There's also the action of the ABS pump to consider. I have a habit of starting the engine and bringing the system pressure up (using the pedal to force all pistons against all rotors) but obviously the powerbleeder is only applying say 20 psi because it's compressing the reservoir. This is where I think the speed-bleeder nipple things could be an advantage.
I like the powerbleeder for flushing the system (no quicker way to get two whole cans of fluid through the system) but I do wonder if it's as good as the pedal.
One last step to keep in mind is to have a vacuum fluid pump to remove the contents of the reservoir down to the filter trap rather than pump this old fluid through the system.
And one more ... never push the brake pedal all the way to the floor ... this forces the piston to make an "excursion" beyond its normal working area of the bore surface. This can bring problems of contamination or abrasion. I put a small piece of wood (just an inch thick or so, nothing scientific) under the pedal so that an overzealous assistant doesn't crush the pedal into the carpet on every pump.
All this talk of brake bleeding has me itching to push some fluid! ... but today is oil filter day ... my least favorite job just because you have to dispose of the all that dino juice and the rose garden never seems to flower quite so brightly afterwards.
Former Vendor
You **do not / ever** want to use Pagid Blacks out back and Yellows up front. Whoever gave that advice...
997 GT3 must use same F&R, otherwise, well, it may not end up well at worst and will feel squirrely at best.
