Trailex trailer
![](https://rennlist.com/forums/images/ranks/veteran_air_force.png)
I have cross-posted this in the 997 as well as in the classified forum.
I have posted the details in the classified section concerning my Trailex 8045 trailer I have for sale. Great trailer in great shape, and the lightest full size open trailer on the market. I just have finally decided on an enclosed trailer and it will be trailex.
Jack @ (830) 303-3640
hmm trailex enclosed... nice! 80180?
I'm also is the process of making a decision on an enclosed trailer, we all know the advantages of an Aluminum Trailer. I would like your input on how you came to the decision of a Trailex and is the lightweight vs cost worth the investment over a steel enclosed, thank you. I would appreciate any and all opinions, let's also assume that the vehicle towing capacity is not an issue.
Best trailer to tow
Best resale
If you decide not to ever go open, it will be teh last trailer you buy
Hello,
I can't disagree with the quality of a Trailex, I owned one, an open trailer and was using a car to trailer and it was an easy tow.
That said, if you have a tow vehicle that can handle the weight of the trailer and car, is the big price of a Trailex really worth it? I would think once your rolling it's pretty much thew same.
I'm asking because I'm considering a Featherlight enclosed and need some advise to determine if the Trailex would be that big a difference, thank you.
WheI think it is.....featherlite is steel frame if I remmeber
n I goto enclosed, it will be Trailex
CAR TRAILER FEATURES & BENEFITS
Check out the features & benefits of a Featherlite car trailer!
All-aluminum construction
Featherlite customers have confidence in knowing their car trailers are made with an all aluminum frame and skin. Car trailer owners prefer the higher payload capacity of Featherlite aluminum trailers, and Featherlites traditionally hold their value longer. With just routine maintenance, Featherlite trailers
I towed my FL 24 and cup car with a Toyota Tundra. Sebring to Lime Rock and every track in between... before the dually and gooseneck w/living quarters
Hello,
The Aluma trailer is a good one. A little heavier than the Trailex (~1350 lbs vs. ~950 lbs) and a lot less expensive ~$1000. Happy with mine.
