OEM Front Axle lift system- retrofittable?
FYI update.... I purchased the Cargraphic airlift system. After some testing the air compressor failed..
The cables were getting realy hot with each attempt.. So make sure you buy the High Performance Air Compressor from cargraphic as well.
Cargraphics Front Axle Lift Repair
Hello. Anyone know of a shop in the NE USA that can repair an air leak in my Cargraphics Front Axle Lift system?
Thank you for your help.
What he said^^
They have a history of breaking, not working properly.
They add weight to the front end.
Take up limited storage area.
If I had one, it would be removed. Then again, I enjoy developing methods of getting around the need for such equipment. My front lip has lasted 3 years. The previous lip only went 1 year because I was just learning how to drive with it. I love living through the challenges of life! Doing it with a GT3 makes it much better.
