OEM Front Axle lift system- retrofittable?
Hello everyone! After years of reading the gt3 threads I decided to buy one
Finally my mk2 gt3 arrived from Germany after 3 months of wait
I bought the car with the lift system but unfortuneatly its not there..Now the dealer wants to refund the lift option. (What an idiot) ....
Is it possible to fit the oem lift system?
Demir
Demir
I should imagine however that the dealer is baulking at doing this since he will have to bare the cost of doing so.
This is just a SWAG, but 'all' it should take is the 'lift' components for the front axle, install the 'LIFT' switch in the dash and reprogram the car to understand
that this option is included ...
Admin
+1 on the Cargraphic - Bilstein airlift. Works flawlessly and is lighter than the oem however the installation is completely different between the two.
The only issue is that Cargraphic's providers, are slow on delivering replacement parts.
Admin
Part number is CARALSP97GT.
Techart's and Manthey’s lifts are hydraulic units. They lift a bit faster but are heavier and for GT3's require modification in the suspension or specific suspension from the companies that sell them. I prefer the simplicity of the Cargraphic’s kit; no oil lines running around the front, fewer parts to go wrong, and very light.
Thank you very much for all the replys
However I need to keep the car stock due to warranty issues etc... I will give a call to Porsce Service center and let you guys know..
If its in the negotiated price for the car you ordered, I'd press the dealer to get something installed and working for the total price you agreed. Especially since alternatives may cost you more and void your warranty. Tough way to start the ownership experience.
I am looking for used GT3s and I would be curious to hear if the installation of an aftermarket lift will void warranty (understanding this can vary dealer to dealer). Any experience with this?
Mike
Mike
Anything is retrofittable...
Keep in mind, besides the accumulator/compressor, switch and the plumbing I believe that the uprights will have to be changed as well as they are different!
