Exhaust for 997.1 GT3RS- What to do?
Just ordered a Sharkwerks centre bypass pipe for my 2011 GT3, hoping to have it installed prior to going to Streets Of Willow Springs in Feb. I'll most likely pass on Laguna Seca due to the exhaust mod, I don't think it will pass sounds check with Sharky installed.
Actually there is a way to make it work at Laguna, and its not very difficult. There is a how-to thread on it somewhere on this forum. It would be crazy to pass up Laguna Seca!
Yes, I believe it's for the stock set-up. I did solenoid bypass last year when I was at LS, I didn't think it would work with the Sharkwerks bypass installed, perhaps I'm incorrect in my assumption.
GT3 player par excellence
^ akropovic passed sound at LS. so i think you can too.
There's an app for that... But you're right, not sure about the bypass.
http://www.6speedonline.com/forums/g...nd-buster.html
But if you want to have a margin of error to be absolutely sure you are ok at Laguna, you may want to put on some diverter pipes to channel any noise away from the sound booth.
http://www.awe-tuning.com/products/p...gt3tipkit.html
No affiliation, just a satisfied customer.
I had a great time at LS last August and would like to return there for some PCA DE events or Speed Ventures event in the future.
While the 997.x GT3 can pass sound by switching the muffler flaps, it also kills power and defeats (pun) the point of wanting to drive through T5 and up the hill wide open. If you put on the turnips, you can leave the exhaust wide open and still pass sound so long as you drive the "sound" line (center to left of center) up the hill.
Carrera GT - maybe there is a misunderstanding. I have the Sharkwerks bypass installed, use the solenoid bypass, and also use the Awe Tuning muffler tips. Haven't had any issues with sound at Laguna the last six days running there.
I didn't buy the Awe Tuning muffler tips recently, but rather a few years ago when we were in disbelief that an unmodified 997 GT3 Porsche could not meet sound at Laguna. By themselves, they do not provide a solution to the sound limitation. I use them now simply because I have them and its easy to take them on and off. I install them so that they are angled to the left and down.
I would caution anybody against just "lifting" or using a particular line through turn 5 to beat the sound cops at Laguna. What happens if you do that is you create a situation where cars that are going relatively slow (because they lifted) are merging with cars that are WOT up the hill from turn 5 into turn 6, which ruins everyone's lap. Its not in anyone's best interest to have that situation occur lap after lap.
I have a center muffler bypass on my car. The car sounds like it should have sounded from the factory.
I've heard both the RSS and the Sharkwerks. Not that anyone should be surprised but they pretty much sound exactly the same.
I'm not totally clear on this.
If the sport button is off and I go over 4k, it gets really loud. Assuming the valve opens automatically regardless of the sport button selection.
With the sport button on, even at idle, it is louder than with the sport button off. It was my understanding that the sport button opens the valve, increasing the volume regardless of rpm.
So what does unplugging the valves do exactly?
