Stop Tech STR Kit Shows Up Today
Fabryce at GMG talked me into Endless brake pads, I do not remember the compound off the top of my head
The best part of the diy.....
I am in my garage doing the work and one of my neighbors (I am not neighbor friendly) walks up and says "you ever track this car"
Long story short.....Ryan Dalziel lives four houses down the street from me. He was one of the drivers of the v8 Porsche that won the 24 hours at dayton a this year.
We talked cars, and delayed my diy......I guess should be more neighborly
GT3 player par excellence
^ cool. now tell him if he lets you do the 24 hours of daytona 2011 then you will allow him to watch you do DIY and maybe even invite him to RL.
Tell Ryan Dalziel not to bother you ... or he can watch if he hold the flash light for ya
So the factory caliper is comparable with ST as far as weight goes
The Endless Pads I am getting are track compound......ME20
http://www.endlessusa.com/brakepad/racing-compound/
Rear PCCB caliper 6 lbs 9 oz
Rear PCCB rotor 11
Quite a size difference between Stop Tech rear and PCCB rear calipers
Stop Tech rear rotor 1/2 inch in diameter bigger than PCCB
Taking photos as I go, will post when done
Rear PCCB rotor 11
Thanks for the pictures and updates, Randy. I can hardly wait for my Stoptech STR kit to arrive. If possible, please post some side by side comparison pictures of the OEM caliper vs. the STR's.
thanks!
Dan
thanks!
Dan
Before removing the caliper and rotor you have to disconnect the brake line
Remove inboard connection (11mm flare wrench) and remove outboard connection (10mm flare wrench)
Stop Tech supplies a plug to cap the line with. I put a plastic bag over the brake resivor cap and retightened it to make a seal
