997 GT2/GT3 Forum 2005-2012
gt3 19's to 18's tires car more unplanted opinion needed
Old 10-22-2010, 06:22 AM
fjpdds
fjpdds's Avatar
Snowboarder54 were the PS2's 18" or 19"?
I use PS2 19" for the street and found them to be quite stable.
I ordered a set of 18' PS2's (Tirerack recommended 295/35) and the rears were about 1 inch taller then the 18 MPSC's(295/30). I sent them back.
Old 10-22-2010, 10:32 AM
Snowboarder54
Snowboarder54's Avatar
They were 19's stock size. I don't have streets here where I live, only roads and very twisty roads at that. I do not recommend PS2's for the GT3. Maybe if you are driving down the freeway at 65 or driving around town, but for me they don't work. They are fine on the 997s, but that's a horse of a different color.
Old 10-22-2010, 10:56 AM
911SLOW
Admin
911SLOW's Avatar
PS2's N rated are perfect on the street in 18s and 19s and although they can't offer the same levels of grip as a DOT tyres does in the corners in a track, I doubt that they would create an issue in the street.
As a matter of fact talking about hi speed highway stability like the OP did the PS2s are excellent and won't creat any issues as long as they are of the correct size and properly balanced.
Those of you that have issues with them, either have something wrong with your car's setup or you are simply asking too much from a street tyre.
John
Old 10-22-2010, 11:07 AM
Snowboarder54
John
John, Do you have PS2's on your GT3?
Old 10-22-2010, 11:11 AM
911SLOW
Admin
911SLOW's Avatar
Yes 18" 315/255
Old 10-22-2010, 11:30 AM
Snowboarder54
I guess it is a matter of preference and driving style. The PS2’s don’t work for me either way. I'm glad you are able to enjoy them.
Old 10-22-2010, 12:34 PM
911SLOW
Admin
911SLOW's Avatar
I do enjoy them, less noise than the 888s and an excellent wet tyre. But all tyres are a compromise for sure, street tires on track and track tires on street don't work the ones in between are again well.. average in both.
Just wanted to point out that in my opinion the PS2s are not dangerous for normal street driving that may include autobahn only legal speeds, besides the PS2s are quite similar in compound with the first generation of Nspec Cups. Only in the 2RS the Ncups gained back their dry abilities and lost completely the less than average wet ones that the first N had.
John
Old 10-22-2010, 12:48 PM
911rox
911rox's Avatar
Can't comment on 18s vs 19s as I don't have 18's.... But I find the PS2s to be ample for street use and they hold well in the corners IMO... Being new to car, I probably don't throw it as hard into the corners as the more experienced guys here... They are my street/ slightly wet track tyres... Cups for dry track at the moment... Stay home for very wet track...
Old 10-22-2010, 05:39 PM
amaist
amaist's Avatar
PS2 is the stock tire for 996 GT3. 235 front 295 rear.
The work fine on the 996 and I see no reason why they wouldn't do well on any 997. It's a good tire for the street.
Where do you drive 130 mph? On the track or on the street? If you are on the track get more appropriate tires. If that's on the street anywhere but Germany I recommend keeping it under 100 mph.
Old 10-22-2010, 05:51 PM
DD GT3 RD
DD GT3 RD's Avatar
If you want to try a cheaper tire for the street, try the bridgestone RE-11.
Great tire, much better than the ps2 in terms of try grip. I have them on my
GT3 and like them, ive never tried running ps2's on this car but used them on my M3. I think the RE-11 is the best non R compound tire. But they dont have 18" sizing.
Old 10-22-2010, 10:45 PM
sasportas
sasportas's Avatar
Default tires
I ran 18" and 19" on my 997 GT3.
18" Hoosier and R888 were great for the track.
The 18" Hoosier was faster than the 19" Hoosier because they had a shorter height all around which gave better "gearing" advantage. Braking and handling were nearly identical.
Quick Reply: gt3 19's to 18's tires car more unplanted opinion needed
