997 GT2/GT3 Forum 2005-2012
CL Nut Lube/Maintenance
Old 10-03-2010, 10:39 AM
KBS911
KBS911's Avatar
Default CL Nut Lube/Maintenance
I followed the new TSB for lube and torque of GT3.2 CL nuts yesterday. It wasn't as bad as I thought. Only took a couple of hours, but that included cleaning the wheel wells, and checking suspension components and brakes while I was at it.
There is a press fit circlip that holds the conical washer in the nut assembly. You have to rotate the washer until you can see the gap of the circlip, then use a small screwdriver to pop out the washer. There seemed to be a decent amount of lube inside the washer/nut interface, however the threads of the nut needed to be lubed. I have had the wheels on and off several times though.
Anyway, glad i took the time to do the maintenance and apply the new torque settings. The 444 lb/ft tightening wasn't any more difficult than the 377 lb/ft spec. I guess in for a penny in for a pound when you are at those values.
Old 10-03-2010, 02:34 PM
Targa Tim
Targa Tim's Avatar
Thanks for the pics. Very informative.
Old 10-03-2010, 03:08 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,630 Likes on 2,314 Posts
excellent, thx for posting.
so the conical interface is held in place by the circlip?
Old 10-03-2010, 03:12 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,630 Likes on 757 Posts
Thanks for posting
If you accidentally drop the nut it falls apart also and it just clicks together once you push the wire ring (Clip?) in. I just ordered an extra nut and center cap as backup.
Where do I order a tube of that paste?
I guess I better pre-grease it, so I have it ready to go.
Old 10-03-2010, 04:00 PM
savyboy
savyboy's Avatar
If you whack the small end on the workbench, it just all falls apart. Seriously.
Old 10-03-2010, 04:44 PM
malmasri
malmasri's Avatar
Great Photos..Thanks for taking the time to post
Old 10-03-2010, 04:54 PM
KBS911
KBS911's Avatar
I guess I better pre-grease it, so I have it ready to go.[/QUOTE]
You can order the paste through your dealer. PN# 000.043.020.00. It is/was in stock in Atlanta so I had it in 2 days.
What I found interesting was that the dealer didn't have it on hand. I was speaking with the mechanic about while I was there and he had the parts department order a tube for the shop.
Old 10-03-2010, 04:57 PM
TRAKCAR
TRAKCAR's Avatar
Thanks shoulda ordered it with the nut!
Old 10-04-2010, 11:54 PM
911rox
911rox's Avatar
Which small end do you mean Savy? The thread side that goes into the hub?
Old 10-05-2010, 01:01 AM
savyboy
savyboy's Avatar
Yes Sir. Sorry, I could have been more clear in what i was trying to describe.
Old 10-05-2010, 01:32 AM
mooty
mooty's Avatar
confidence inspiring!
you should me next time.
Old 10-05-2010, 07:34 PM
911rox
911rox's Avatar
Thanx heaps Pete, will give it a crack when I have them off next...
Ps. Thanx for the pics and info KBS911... much appreciated...
Old 10-05-2010, 07:42 PM
Larry Cable
Larry Cable's Avatar
Received 3,597 Likes on 2,340 Posts
shouldn't you get a stronger workbench then? bada boom ...
I crack myself up ... :rolfmao:
Old 10-05-2010, 08:37 PM
axhoaxho
axhoaxho's Avatar
Excellent post, thanks for sharing.
Old 10-05-2010, 10:12 PM
savyboy
savyboy's Avatar
A tough crowd here...haha.
Some days I am better off not even trying to post...lol. Eventually I will figure out how to convey a thought in straight forward manner.
Quick Reply: CL Nut Lube/Maintenance
