Laguna Seca Sound ... check! ... problem (finally) solved
Wordsmith
Here's the solution:
These tips are as simple as they look.
With these on, a 997.1 GT3 or RS or 997.2 GT3 or RS can run wide open 3rd or 4th gear past the sound check station at Laguna Seca and be under the 92 dB limit.
I also put on the (brilliant) side muffler butterfly valve actuator control switch (thanks mikymu!) and it works fine "quiet" mode on its own (just a flip of the switch while downshifting into T5, then flip it back to "loud" as you downshift into T6 and no complaints from the sound check monitors. But I'm sure it costs some power up that long uphill straight. So the elbow tips are great.
i know sometimes they have someone with a roaming microphone that hangs around front straight and pipes normally bent away from the sound station are now pointed right at them. wasn't just the switch enough to pass without problems?
Wordsmith
Right -- the switch alone with stock tips works fine.
We need to post a thread of everyone's Laguna Pipes. There is some pretty interesting apparatus out there........
"that will invalidate your warranty"
Wordsmith
Welded inside. There's not a lot of weight in those elbows -- you could make the same thing by getting a U stock and just stuffing it in there and putting in a couple of short bolts through the sidewall (which would also make it easy to run the pipes at other angles (such as for another track where the sound check is on the other side.)
Wordsmith
It is obvious this worked for Carrera GT because I was there. However I have had the best luck pointing the exhaust at a 40 degree left to the ground. It seems to knock off at least 2DB from the reflection. I run a resonator in my BMW race car that seems to work unless it is foggy.
This is the only setup that has no restriction on the outlet. Another setup at the track last weekend had the two 3 inch outlets combine into one 3 inch. It's only for a four inches of pipe length, so it's probably not a lot of restriction, but it's still a restriction. That design ends with a small downturn.
Wordsmith
These were a one-off hand fabricated set I borrowed from another guy in the paddock because it was working on his 997.1 GT3. Just a piece of U stock welded into the factory tips.
I believe Alex at Sharkwerks has a batch of adjustable tips going into production, so for anyone wanting "nice tips" I'm sure his product will be good. Having the ability to adjust through any range of angles will be handy for other tracks. Being able to remove the elbows for the drive home will be useful too.
Yep with CarreraGT's prodding and another Brit's help we should have something shortly. We'll be sure to make it so it fits the new RS' too
Wordsmith
It works with the rear muff delete from Sharkwerks insofar as other posts here have said the exhaust flapper valve switch works with the delete pipe and I know this elbow tips solution works with the switch on wide open loud, but I don't know if it works with other delete pipes. The delete pipe is pretty simple, so long as it doesn't increase the exit pipe diameter at the flange (where the tips bolt on) I wouldn't expect a difference.
