Pagid part# for front pads 2010 gt3??
Hi fellas, for those of you who have already done a pad change, what is the correct part number for the fronts on a 2010 gt3 (380mm steel rotors)??? I am planning to change to Pagid RS29s... Is it the E2707 for the front??? I believe the rears are 8006s... does that sound right? The pagid website doesn't provide specs for the current GT3 but I know a number of the guys here have already made the change...
Also, for those who have swapped out the OEM pads, did you take note of what compound the original pads were (from the writing on the back)???
Thanx in advance
Thanx in advance
GT3 player par excellence
8004
2707 are for '07-09 Gt3s, 8004 are for '10 gt3. Do a search, I think Trakcar had a thread with pics (he originally got 2707s for his '10). The 8004s are chamfered at the end by a few mm to fit the rotors.
Thanx again rmag I do recall this issue when mikymu did the conversion to cup rotors, didn't realise it included the '10 steel rotors... Obviously our distributor isn't up to speed yet...
I had the same issue, they delivered the wrong pads (2707). Result is that the inner 2mm of the pad are not touching the brake disk. 8004 is the correct number. The distributor didn't even realise they were delivering wrong pads until we pointed it out to them, and they replaced my set of (slightly used) pads with the correct ones free of charge.
These are actually the pads for the 997 cup car.
