any experience with side muffler deletes?
Anybody ever use the Fabspeed side muffler deletes on stock GT3 exhaust?
i have a set that i would like to try, however im curious of the DB level??
I have tried supercup exhaust (sans mufflers) and was fun but too loud for most tracks.
Im back to stock exhaust.
Im now considering using my fabspeed side muffler deletes with stock center muffler for low DB requirement tracks (if possible) and using my sharkwerks center with the side deletes for tracks with no requirements.
basically my goal is to only need to swap centers depending on tracks all the while having no side mufflers!
I had a Fabspeed exhaust on my GT3.1 and thought they were the sweetest sounding exhaust for a GT3. Funny but the car sounded more Italian than German - ha ha ha. It had high flow cats. Definitely not loud.
i used to drive with straight pipes and no mufflers and not much problem, only at high rpm. I only had stock headers and cats to act as a back pressure devise.
Former Vendor
I went unplugged on my GT3 for about a week, but it got annoying with that drone between 2-3.5k.
Sharkey total bypass system plus EVOMsit is a symphony to my ears at all RPM's, but clearly not passing on many track sound level limits...
do they have limits on T & T days as well? What about racing days?....I stopped DE years ago secondary to the restrictive aspects.
I suggest you keep the RS as you like for the street and just go full blown CUP for real racing and be done with all the silly constraints.
The Rebel
I don't have any mufflers with a full FVD set up.
In other words FVD Headers with 200 cell cats and then straight piped all the way out and it's loud as ****! I like it though.
Two things:
1) it's really loud
2) Based on FVD's research the engine needs more back pressure and therefore we installed an FVD center muffler (still much less restrictive than stock but more back pressure than straight piped).
There first video is straight piped the second has the FVD center muffler.
Two things:
1) it's really loud
Two things:
1) it's really loud
Two things:
1) it's really loud
Did you have the ECU flashed as well?
The Rebel
ECU was flashed...PM Rhonda from FVD for more data. All I have is this:
The first one is for the straight piped and second for the center muffler set up:
**These are from a someone else's RS with the exact same set ups**
THE SYSTEM IS DESIGNED AND BUILT BY M&M EXHAUST
