Pass Laguna Seca sound limit in 3.2 seconds!
#61
I have the Sharkwerks Laguna pipes but am blowing nearly 104db at WOT with all three mufflers. Has anybody added something like Supertrapps to these? If so, wondering what the results were.
#62
I was able to run 92db days at Laguna with OEM exhaust and locked out the flapper from opening to bypass the side-mufflers. It felt lethargic going up the hill, but no black flags!
#64
I was (just) able to pass 92db with a Sharkwerks bypass and the 3sec mod, but only JUST... I think I was 96+ w/o.
#65
forum search is your friend: https://rennlist.com/forums/showthread.php?t=553357
#68
I have a 90 db day coming up next month and wondering if I'd be able to pass with this or maybe I need to add direction pipes also? I have OEM stock exhaust. Sounds like this will pass the 92 db limit, but not 90 db? I don't see the pipes listed on Sharkwerks, is there another source?
#69
Depending on how overcast it is, wind direction, and where you put the car on track (far track left as you pass sound) you might be able to pass with this "bypass" option.
I passed in my old 997.2 GT3 RS with stock exhaust doing this...but I asked for a sound check a few times and it was really close to 90
If you can, having a set of directional pipes is preferred
#70
#71
I think S/W may have stopped making those tailpipes ...
#75
Two questions on this fantastic mod:
1. Is heat build-up a problem on track with the valves in quiet mode?
2. Has anyone tried this mod with a BBI Autosports center muffler on a 7.1 GT3? Read the posts on the mod working with the SW bypass, but I think the BBI bypass may be louder due to the slightly flared tail pipes.
Matty
Matty
