Front Strut Brace for GT3, GT3RS or GT2 ?
Hey great photo "thusly".....it nicely shows the unibody cross member hidden between the strut towers, two addtional black diagonal braces, and the roll cage bars coming through from the cockpit. The latter adds additional bracing in the longitudinal direction.
Interesting....keep it coming!
Cheers!
Doug N.
Cheers!
Doug N.
Cheers!
Doug N.
Cheers!
Doug N.
Just to be completly clear. The intent with in my post you quote above, I was seriously truly thanking you for posting the excellent photo.
Cheers!
Doug N
Cheers!
Doug N
A front strut brace may help maintain the front camber alignment when the forces required for torquing the center lock bolts are considered. Once, when tightening a front center lock bolt on my '11 RS, the strut moved in the outboard direction in the strut tower top within the slots in the strut tower. Because I noticed it, I was able to move it back to the intended camber position because I had marked around the nuts that hold the camber plate in the slots in the strut tower.
I know this is a really old thread, but just wanted to point out something I discovered and that the if its not on the cup adage doesnt apply anymore:
Pat number: 99750423390
Page 15
http://pgt3ccb.com/images/media/Tech..._addendum1.pdf
You can see it installed here, took this from the install manual for it. It bolts on to the top of the shock towers as well as the tub wall
Page 15
I have this strut bar. I have not installed it, but it requires drilling holes on the center of the firewall and installing a few rivnuts.
I actually purchased the exact strut brace shown in your image above from a "Carrera Cup team in Australia. It was apparently required for the Carrera Cup cars starting 2012 or 2013 to reduce front end flex issues.
If I was home I would take a look and post pics, but I won't be back until November if at this point.
i can't see how with street tires or r comps this is going to make a difference. full slicks with 800/1200 lb springs and full tilt driving, sure.
How much are these things brand new?
Would be nice to know why Porsche updated the rules in that region requiring all teams to add this.
Yup, that's the one. It was $100-150 shipped all they way from Aus or NZ.
I have a front aluminum strut brace on my car and I believe it works. The reason I say that is that I forgot to tighten it on time after I reinstalled it following an alignment. I kept getting a loud squeak when going over uneven pavement. drove me nuts until I discovered that it was loose. Once I put a preload on it and tightened it up all the squeaking went away. The squeaking was obviously a result of the bar moving due to chassis flex. So yes, the strut brace works.... I do run a stiff suspension with 1400/1500 springs so there is a lot of load going through the chassis and I feel the strut brace is definitely a big help in stiffening up the tub.
