2010RS 15+HP how?
Just curious if anyone knows the RS details yet.
The torque is the same I believe, but where does the 435HP->450Hp = extra 15HP come from?
Is it just the bigger "Ram" air intakes, or a different program also?
Maybe the final titanium muffler?
Maybe it is mostly marketing?
They could offer an "RS power upgrade kit" for GT3's, or would they void warranty?
GT3 player par excellence
compresssion:
RS 12.2:1
GT3 12.0:1
RPM
RS 450 @ 7900
GT3 435 @ 7600
and most importanly, BS and imagination.
RS 12.2:1
GT3 12.0:1
RPM
RS 450 @ 7900
GT3 435 @ 7600
The RS airbox has dual inlets, i.e. a bigger inlet. Porsche said formally that the intake makes the power gain, but I don't believe it is the main part of it. The .2 bump in compression should be good for 2% more power; about 9 of those 15 ponies. The rest would be the better breathing intake box. Does anyone know how thye bumped the compression? CNC program change on the heads, thinner head gaskets or different pistons?
Didn't I read somewhere different cams as well
If you add compression, larger intake, cams and you give up a few #of tq down low 15 added hp seems about correct - my guess is that it may be closer to 20 to 25 with an aggressive cam
Thanks!
I suppose the Dyno will tell.
It would be impossible to tell on track with the diffrent gera ratio's...
Hmmmm...
We were told by Andreas at the launch that the difference is actually greater than stated...
This is what the brochure says:
The 3.8 liter engine in the new 911 GT3 RS delivers even more power: 450 hp. The output is 118 hp per liter. This increase is due to the two new double-flow air filter housings and the new variable intake manifold with larger intake tubes than those used on the 911 GT3. The greater throughput of air increases engine power. In terms of performance data, the maximum torque of 317 lb.-ft. is reached at 6,750 rpm.
