well, ABS Ice Mode finally got me...
#122
Former Vendor
Chuck
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
#123
Chuck
The standard Cup car does not have ABS (so easy to change tyres, its all down to driver talent), the R does have a race ABS system and is targeted at non-professional drivers in GT3 class races. The RSR also does not have ABS.
Some race series do allow entrants to retrofit ABS on their GT3 race cars. The Bosch ABS M4 kit can be set up with multiple programs. This link points to the ABS M4 kit manual
http://www.bosch-motorsport.com/cont..._Manual_en.pdf
Required reading for anybody interested in brake issues.
I do not know about the US Cup series, but most (all?) other cup series for current model cup cars do not have ABS.
The MS ABS allows entrants to turn off any or all of ABS, EBD and TC.
R+C
R+C
#124
So the moral of the story, if you have a GT3 and plan on modifying the suspension, tires, wheels, etc. you should also plan on spending more money on an ABS M4 kit as well (plus programming of the kit). If you don't you run the risk of ice mode.
Man if I was a 7GT3 owner I would be pissed!!!!
Those 993's and 996's are looking better and better for track duty.
#126
Former Vendor
Chuck
R+C
R+C
Off course your right! I can only attribute that mistake to staying up too late! Thank you also for the link! Looking forward to hearing your additional comments. Chuck
#127
GT3 player par excellence
#128
Ha! This is something I've been arguing in favor of since the 964! There's still no better way to get the pedal feel (and unassisted steering feel) that is otherwise dulled or even deleted by "power" systems. The hydraulic amplification of the manual braking system is ample to generate 1000+ brake horsepower; how much more is needed?!
#129
I've been reading this thread with utmost interest. Just very recently, I experienced this ABS ice mode on a sweeper.
Conditions: Dry, night, mostly smooth pavement, Road was a left hand sweeper, on slight camber, headed downhill.
I take this sweeper at least twice a day, and i'm very familiar with the speed and always leave something on the table. I hit the brakes (trail braking) and suddenly, for the first time, the pedal firmed up to the point where I was definitely not decelerating.
I let off the pedal slightly and applied pressure again, trying desparately to slow down, which I did enough to continue on, but the re-application of the pedal freaked the abs/PSM/etc out a bit to much.
We came to almost a stop and then the dash lit up like a christmas tree. I've had this before in another instance, but never bothered to remember the exact circumstances.
I believe it's the wheel speed/ABS sensor. Now, I'm not sure whether it's the sensor ring or the actual ABS unit or another black box in the car. I've had this happen in my S4 too on the track and I chalked it up to freaking the ABS/EBD out and going beyond a certain parameter (yaw/steering angle/braking combination)
Anyhow, I'd add my two cents. BTW, I got home, turned off the car and turned it off and the car didn't seem to think anything else was wrong. The fault hasn't returned, but i'm sure I can try for another round if I want to be brave.
I happened to grab my phone
http://www.youtube.com/watch?v=ki2vo...layer_embedded
#130
I've not had the ice pedal in street driving. I think the next time I'm at Laguna, I'll be running video and data acquisition, perhaps including a video camera on the pedals, and spend a few sessions trying to repeatedly invoke ice mode as many times as possible to try to make it reveal its root cause. I'm all for going to non ABS and non power-assisted brakes!
#132
Admin
#133
#134
I'm definitely having the ABS wheel sensors looked at. They're original.
I'll report back. Odd, indeed.
#135
It's a matter of the work the pads and rotors can produce at say 60 or 100 mph, not the ratio of pedal force to caliper piston clamping force. I'm sure there's some brake design sites or "how it works" pages at some of the vendors like stoptech to explain swept area, heat production, leverage, as well as clamping force, friction coefficients, etc. Perhaps the pad makers like Pagid would have formulas (formulae?) for each of their compounds operating against a given rotor composition or alloy.
Whatever the engineering, while we think of "powerful" engines in the 500hp range and capable of sending the car to 100 mph in three seconds or whatever, the brakes are twice as powerful (or more) and can bring the car back to a halt in a matter of 80 feet (or 120 in the case of a BMW.)
I'm usually trying to threshold brake at the limits of the tires' adhesion and do this with my big toe. I am curious to see what happens if the booster is removed from the channels of communication and I might have to use all my toes to modulate the pedal. Or maybe I'll crash.
