Need help mounting my JRZ rear external canisters
Im having my new JRZ RS Pro's mounted.
The problem we ran into is that they arrived with no quick disconnects...
I want to mount the rears inside the cabin on the roll bar... but I would have ti cut a hole large enough for the hole canister to fit through into the cabin.
I rather not do this but I DO want them inside.
My only other option is to mount them where my side muffler used to be (deleted side mufflers).
Please let me know where you guys mounted them and where???
Also if I do cut a hole where is the best place to do this?
They fit under the carpet with the GT3/GT2 logo, right below the aluminum panels that hold the wiring harness and ECU.
These pics are from my old car:
![](http://members.rennlist.com/nj_gt/rear-canisters1.JPG)
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Peter
I found a spot under the rear seats where we just had to notch and fit them through.... so no frankenstein work had to be done to my baby.....
anytime a grinder or saw gets to close to the car i get squeamish ;(
NJ GT
thanks for the pics.. im either going to mount them on the roll bar or in the spot you show
thanks and i will post pics after we finish the install on wednesday...
suspension is in... now we just have to dial in the set up... put in the roll bar and sparco's
