Very high clutch pedal GT3
My clutch pedal does nothing the bottom half of the travel and it only grabs at the very last inch of the travel, I have the LWFW.
Is this normal?
Is this adjustable?
I think I am pretty easy on the clutch, but could it be wear?
It has not changed since I got the car 9000 miles ago.
Thanks!
Is this normal?
Is this adjustable?
Thanks!
mine has a fairly high release that seems to be consistent. I have 28K miles on my car now. I do notice, however, a "creaking" noise at or just beyond the release point that is more pronounced when the car is warmed up fully.
Wished the release point was a little lower or make some kinda clutch stop so u don't have to depress all the way down. My friend has a clutch stop on his e36m3 from turner Motorsports- felt great when I drove it. Mike
That is pretty normal in these cars, especially with a fresh clutch. Pickup is normally in the top 3rd of the pedal. When the engagement point drops toward the bottom, you know you have a problem.
Mine is the same. Always been that way.
Now about that ratteling (Not a light rattle, rather like there is a lose shock) on washboard roads from the front end :-) specially going 30-40 MPH over broken up pavement the front end only. It will not do it slalomming, under breaking or acceleration on a flat road, just when cruising straight over..
Always done it, still normal?
Old thread, I know...
Anyways, my new 2011 GT3 intially had a clutch engagement point of half way up (or just under) during the break in period. At 1700 miles I took it to the track and everything went great. Now (2100 miles) the clutch engagement point is very high, almost at the top. Car performs great, no clutch slippage, no noises or rattling. I assume this is still normal? Thanks.
