Porsche has made it simple to configure an RS
Option 585 gives you Cupholders above glove compartment. Integrated into switch panel behind the trim. Note: Decorative cover without RS 3.8 logo
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Thanks MJ. So then...
Std empty weight = 3020#
So if the delete options are:
Headlights - 13 lb.
Radio - 8.8 lb
A/C -?????
Optional Lithium battery 22 lb. (OE option or not)
Then are we looking at a 2976# dry weight? I'm likin that!
Headlights - 13 lb.
Radio - 8.8 lb
A/C -?????
Reference the paint scheme: It looks to me like you need to specify option code 510 (contrasting color) to get the graphics and colored mirrors, etc. Does this mean that not checking option 510 leaves the mirrors, wing plates and front intake in body color? All white, for instance... Am I understanding this correctly?
510 for Red constrasting color
511 for Gold white constrasting color.
But you have to chose one, sadly.
Possibly... although the 'Must Pick' column is blank beside the Grey Black color column. If it was mandatory, you would think it should be indicated there. On the other hand, there are lots of errors and omissions in the Order Guide and probably the only way to know for sure is to input an order, electronically, at a dealership.
