Bleeding the Hydraulic Clutch
Does anyone have a DIY on bleeding your Hydraulic Clutch. I think I know where to add the fluid but how do you get to it to flush and replace the fluid. Also anyone know how frequent it should be done?
Use a power bleeder (like Motive) - just like bleeding the brakes.
I like to see pics it make it simple Stupid.
http://www.6speedonline.com/forums/g...d+fluid+change
This is an easy DIY the hard part is finding the fill plug. Its on the drivers side of the trannie and up next to a cooler fin. Not much room to work. I then bought a 6.00 fluid pump and filled it with mobile delvac.
also you need to buy the allen wrench you cannot get a socket up in there.
