997 GT2/GT3 Forum 2005-2012
lowering my 997 GT2
Old 05-01-2009, 08:53 PM
mhd212
8th Gear
mhd212's Avatar
Exclamation lowering my 997 GT2
Hi guys,
This is my first post and i am happy to join you.
I have a small problem which am sure crazy gt2 owners has faced>>>
I tried to lower my 997 gt2 and to get every penny out of it by using everything it has :P.... however, the car didnt drop from the front although I spined all the coilover down to bottom.. any tips I should know about the suspention of this nice car?
Old 05-01-2009, 08:58 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Hi MHD, Welcome to Rennlist, I moved this thread to the 997GT2 Forum.
Old 05-01-2009, 09:48 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,741 Likes on 2,350 Posts
Originally Posted by mhd212
Hi guys,
OT, nice car.
what is the color called?
ruby red?
Old 05-03-2009, 06:23 PM
va122
va122's Avatar
um, your car will have severe bump steer. you need to change the uprights and get a bump kit f/r
va122
va122's Avatar
what GT2 forum???
Old 05-04-2009, 09:07 AM
mhd212
8th Gear
mhd212's Avatar
yea the collor is ruby red
i dont have any problem with lowering my car sine there are no speed bumpers around my place
thats why I am soo keen to lower it.
Any idea how to lower the front?
Old 05-04-2009, 11:29 AM
mooty
mooty's Avatar
^ your car is on fully adjustable coil overs. just take it to a good race shop and they can lower it to the pavement. do keep in mind your suspension geometry may be negative affected if lowered too much.
Old 05-04-2009, 12:22 PM
pmf
pmf's Avatar
On standard coilovers you should not go lower than -10, otherwise the spring does risk to move when lifting the car or on a bump.
Changing dampers for something with pre-load springs, you can easily go as low as -20.
At -25 you put too much weight on the front (as you cannot lower the rear enough to keep the balance), so I would not do it.
At -20, anyway, a careful alignment should be done. Firstly, because of increased bump steer, which you can compensate someway going to neutral toe; this is anyway something you should like driving with: as anything related to alignment, it is rather subjective and related to your driving style. Secondly, you should increase negative camber a bit more than you are used to; you have to check this properly with tyre temperatures; by the way, to increase front camber more than -2.5*, you need to rotate the cookies.
Hope this helps,
Cheers.
Old 05-04-2009, 02:54 PM
LastMezger
LastMezger's Avatar
Hope this helps,
Cheers.
Twenty bucks says this goes right over his head.
Old 05-04-2009, 05:13 PM
Z06
Z06's Avatar
Hope this helps,
Cheers.
What kind of front to rear rake do you have?
Old 05-04-2009, 05:47 PM
NJ-GT
NJ-GT's Avatar
Hi guys,
moving the spring perches down in an axle will definitely lower the car, don't get confused by the shocks not being fully compressed as soon as you drop the car from the jack stands or floor jack. Drive the car for a few miles and you will see the new ride height.
Most likely, you have messed up the alignment, because dropping the ride height changes camber and toe.
Old 05-04-2009, 06:05 PM
pmf
pmf's Avatar
No idea, to be honest
The only thing I can tell you is that the front is 553kg, the rear is 913kg, for a 38%front / 62%rear weight ratio
Silly enough, I didn't weight the car with the factory standard setup to note the std weight ratio, but I think I'm not too far from correct
P
Old 05-04-2009, 07:51 PM
va122
va122's Avatar
no no no, he's talking about chassis height ratio f/r Incredibly important.
If he lowers it below 90mm it will be undrivable without more suspension changes. IMHO
Old 05-04-2009, 08:52 PM
tcsracing1
tcsracing1's Avatar
anybody know how high can you raise a gt3/2 within reason?
Old 05-04-2009, 09:28 PM
NJ-GT
NJ-GT's Avatar
40mm
Quick Reply: lowering my 997 GT2
