997 GT2/GT3 Forum 2005-2012
My RS loses 74lbs the hard way - Pics
Old 01-22-2009, 08:42 PM
  #31
Carrera GT
Wordsmith
Carrera GT's Avatar
<ignorance>
Is the intake plenum designed for a restrictor plate?
Perhaps it's just a theoretical limit of the engine.
</ignorance>
It's a little more fiddly to get to the "top service" oil filter now ... : )
Old 01-23-2009, 11:58 AM
  #32
Petevb
Petevb's Avatar
Originally Posted by grussell
Here are a couple of pics with the new motor in the car and the intake being fitted.
Grussell,
Which version of the intake is that, and what part of it if any is custom? We looked briefly at fitting one of the RS/ RSR intakes to my 997 cup motor, but the one we had didn't come very close to matching up with the cup ports, so we dropped it. This seems like it was designed to fit, though, and looks pretty slick...
-Pete
Old 01-23-2009, 12:04 PM
  #33
grussell
grussell's Avatar
Originally Posted by Petevb
Grussell,
-Pete
The RSR throttle bodies are mounted to 3/8" thick aluminum plates that relocate the throttle bodies to line up with a stock RS CF plenum.
Old 01-23-2009, 02:27 PM
  #34
Carrera GT
Wordsmith
Carrera GT's Avatar
What are those L shaped connectors coming out of the spacer plates? Are you going to run nitrous?! : )
Old 01-23-2009, 02:33 PM
  #35
grussell
grussell's Avatar
Vacuum lines for the Motec ECU
Old 01-23-2009, 02:54 PM
  #36
grussell
grussell's Avatar
more pics.....
Old 01-29-2009, 07:38 PM
  #37
grussell
grussell's Avatar
The final weight after corner balancing is....
2520lbs, 250lbs less than a new 09 997 Cup!!!!
Dyno next week. I hope to see 475RWHP
Old 01-29-2009, 09:58 PM
  #38
mooty
GT3 player par excellence
mooty's Avatar
Received 5,764 Likes on 2,361 Posts
bastard.
you'll lap me 5x in a 20 min session.
Old 01-29-2009, 10:28 PM
  #39
deutschmick
deutschmick's Avatar
You, sir, are my hero.
Great work!
Old 01-29-2009, 10:48 PM
  #40
Carrera GT
Wordsmith
Carrera GT's Avatar
475 to the ground?! Are you nuts?! Scratch that. Redundant question. : ) The engine is going to be quite something. I trust you'll be doing justice to the car with a high quality mic and HD video of the dyno runs. : )
If that's about a 20% drive train loss, you're aiming for over 550 at the flywheel, even an impossible 10% loss with an exotic gearbox you're asking for 520-530 HP. And I imagine you're shooting at 8500 rpm? Higher?
Power to weight, that's 550 into 2520. Is that about 4.5? I guess if you were shooting for 5lb/hp, you've certainly reached your goal and then some.
I've driven my car (3000lb) tuned to about 440 at the wheels (aiming for about 520 flywheel) and it was marvelous (993 Turbo in AWD) but still drivable and fun without being too much (Bob did the "too much" car ...) At 2500lb, the brakes, the apex speeds and G loads will be neck-snapping. I hope you're a lot more physically fit than me! I rode my dirt bike (Aprilia RX550) for half an hour today just to burn off some calories and make sure the tweaks I made this week are dialed in and ready for a trip next week. My legs feel like I must have won the Boston marathon ...
Old 01-29-2009, 10:49 PM
  #41
Carrera GT
Wordsmith
Carrera GT's Avatar
Originally Posted by mooty
bastard.
Dude, I was doing that when we drove in the rain at Laguna ... and I was in the Cayenne ...
(Kidding! Just kidding!)
Old 01-30-2009, 01:34 AM
  #42
mooty
mooty's Avatar
of course you were.
i wasn't there. you must passed my phantom GT3 100x time in one session
Old 01-30-2009, 01:44 AM
  #43
ritzblitz
ritzblitz's Avatar
Wow this car is insane.
Old 02-05-2009, 02:03 PM
  #44
grussell
grussell's Avatar
The final numbers are in....
2520 lbs with 2 gallons of fuel
466 RWHP at 8000 RPM
Old 02-05-2009, 02:56 PM
  #45
RWK
RWK's Avatar
Absolutely fantastic! Thanks for sharing. What an incredible project!!
As CGT said, the fittness to drive the thing will be serious.
(CRF250/ 450 honda trianing machines here)
Quick Reply: My RS loses 74lbs the hard way - Pics
