997 GT2/GT3 Forum 2005-2012
laguna seca
Old 10-22-2008, 03:12 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,531 Likes on 2,288 Posts
Originally Posted by NJ-GT
What's the whole deal about stuffing foam in the airbox? Will a quiet exhaust still trigger the sound meter?
I ran the 996 GT3 without problems, and both the 996 and 997 GT3 use the same airbox design. The only difference is the intake scoops that 6RS, 7GT3 and 7RS have, but 6GT3 doesn't.
stock RS or 7gt3 is about 95dB or more when they measure it at LS. (with sport button off)
with turn down pipe and foam in air box, i got 92.6dB.
this is very consistent, i have NEVER seen stock cars pass sound, unless the flaps are wired close permanently.
i heard a car from so cal that passed sound with just turn down pipe. i think the driver is not really at WOT in 3rd gear. there is no way in hell you can pass sound in 3rd up the hill WOT and on the fast line. if you move way track left, perhaps.
Old 10-22-2008, 06:00 AM
jrgordonsenior
jrgordonsenior's Avatar
Rad sound resonates out of the large throttle body of the GT3's and that soundis not directed away from the meter. Taping or securing foam under all the openings of the deck lid and around the air box is very effective at reducing the decibel level at Laguna.
Another consideration is the weather. If it's foggy morning I don't waste my time trying to go out until the fog lifts. Sound bounces off the pavement up against the heavy morning fog and back down to the meters. Too many people have these turn down tips which just bounce the sound off the pavement. Try using zoomies (elbows) and direct the exhaust away from the meters....
http://store.summitracing.com/partde...5&autoview=sku
Old 10-22-2008, 01:59 PM
lawjdc
lawjdc's Avatar
If you need to use foam to dampen intake noise, then fuel cell safety foam works well. Just cut a piece to fit into your air filter box, and it will drop your noise by about 2 db at Laguna Seca on an 997 GT3.
Old 10-22-2008, 03:31 PM
speedoflight
speedoflight's Avatar
Originally Posted by mooty
M5 too big. take GT3. you will like it.
big and heavy! but i'd rather stick around the whole day tracking than be sent packing early in the gt3. i'll check you guys' setup there and see how you're able to get around it as i'm not really clear how you guys stuff these foams/pipes, etc... to drop the sound within limit.
Old 10-22-2008, 05:59 PM
mooty
mooty's Avatar
good point.
i'll bring some foam to show you.
my car has been "turned down" so will pass sound as is. it doesn't sound nice like yours or daytona violets.
Old 10-22-2008, 06:12 PM
NJ-GT
NJ-GT's Avatar
good point.
So, stock exhaust + AWE turn downs + foam. What else?
Old 10-22-2008, 06:18 PM
speedoflight
good point.
yeah i thought your car was 'quite'. is yours already with the bypass or stock?
Old 10-22-2008, 07:01 PM
mooty
mooty's Avatar
i had all above, failed sound.
so i short shift after T5 and move track left (the correct line would be track right and the sound station is of course on the right). then i pass sound.
you can rig the vacuum flaps to remain shut all the time (the open at 4k rpm i think) then you are ok.
mooty
mooty's Avatar
the white car is all stock.
i had an RS, that had bypass.
Old 10-23-2008, 02:27 PM
speedoflight
the event is cancelled.
Old 10-23-2008, 05:07 PM
daytonaviolet
daytonaviolet's Avatar
aww.. i wanted to bring my csl to this even too
Old 10-25-2008, 08:56 PM
dertub
dertub's Avatar
Question
Hey, Mooty did you sell the orange RS?
Old 10-26-2008, 12:57 AM
mooty
mooty's Avatar
you got pm
Old 10-26-2008, 01:48 AM
crispenigl
crispenigl's Avatar
Originally Posted by OldGuy
I know, its just my buddy contacted the wall there before. I can go till after surgery anyway in my AMG.
AND I have driven it a million times on PS3!!!!!
i thought i knew the track because of the millions of miles i have driven LS on ps1,2 and xbox... but it is so different in real life.
i cannot believe how steep the cork screw is.
the track is amazing and the area around it is gorgeous...
truly awesome.
im driving a formula mazda and not my gt3 tho...
Quick Reply: laguna seca
