997 GT2/GT3 Forum 2005-2012
Brake calipers the same for iron and PCCB?
Old 06-27-2008, 04:24 PM
SixSpeed
SixSpeed's Avatar
Default Brake calipers the same for iron and PCCB?
Are the (red) standard brake calipers on the GT3 the same as the (yellow) caliper used for the PCCB setup, or are they different?
Thanks.
Old 06-27-2008, 05:01 PM
RonCT
Moderator
RonCT's Avatar
Different.
Old 06-27-2008, 05:36 PM
340Elise
340Elise's Avatar
Originally Posted by RonCT
Different.
Just to confirm (since I have both sets and the front calipers are on my kitchen table), that is correct.
Old 06-27-2008, 06:01 PM
On Pole
On Pole's Avatar
What is the difference?
Old 06-27-2008, 06:10 PM
Max Power
Max Power's Avatar
I would guess because the ceramic discs are larger, the yellow calipers have less curve to them?
Old 06-27-2008, 07:14 PM
SixSpeed
SixSpeed's Avatar
Can you use the red calipers with PCCB disks, or do you need to go to the yellow caliper?
Old 06-28-2008, 02:39 AM
C.J. Ichiban
Platinum Dealership
C.J. Ichiban's Avatar
Received 2,062 Likes on 581 Posts
have to use the yellows. they're much larger and calibrated differently I'm sure as well. PCCB is an entire system, and the only thing I know that's mutually compatible is going with the iron cup car rotors and reusing the yellow calipers. if you've got the reds, you've got options but PCCB isn't one of them unless you want to swap out everything.
Old 06-28-2008, 03:00 AM
Carnerd
Carnerd's Avatar
This is somewhat OT, but are the 996 CCB calipers the same size as the reds? I would assume so as both employ a 350mm rotor.
Old 06-28-2008, 05:50 AM
340Elise
340Elise's Avatar
Nope. I am currently swapping to the PCCB's and doing it myself. You need the calipers, rotors, pads (I think), and different front uprights because of the larger front discs.
btw, I will post this in my thread on this swap, but the weight savings is 44 lbs, and that is from only the rotors. The calipers weigh the same and I can tell you that the uprights are almost the same and can only be a few onces off due to the extra aluminum to bring the front caaliper further out.
44 lbs!!! I have been weighing everything with multiple scales and methods. I am happy now!
Old 06-28-2008, 01:06 PM
zizu
zizu's Avatar
I was reading on the Porsche web site that the yellow calipers are aluminum while the red ones are steel. However they pretty much weight the same since the yellow ones are bigger.
Old 06-28-2008, 02:49 PM
MJones
MJones's Avatar
One other thing to note:
Steel and PCCB calipers are "clocked" at a different angle.
Old 06-28-2008, 04:07 PM
340Elise
340Elise's Avatar
Ah, that explains it; I was wondering why the front yellows weighed about the same, if not a little less.
I still need to measure the rears, maybe there is another lb on each rear caliper to be had. If so, then we are at about 46 lbs. I will check this today (my rear reds are still attached to the brake lines).
Old 06-30-2008, 09:05 AM
Max Power
Max Power's Avatar
Then a magnet would stick to a red and not a yellow.
Steel is mostly iron.
Aluminum is non-magnetic. (paramagnetic)
Old 06-30-2008, 10:36 AM
RonCT
Moderator
RonCT's Avatar
All Porsche brake calipers on the 997 GT3 are aluminum whether PCCB or not, 6 piston front and 4 piston rear. Larger pad surface area with the Yellows and 380 mm rotors vs. 350. The hats on the PCCB rotors are aluminum, thus much of the weight reduction. I've heard, read, and listened to serious track guys that bought a 997 with PCCB and have since removed the ceramic rotors and put steel cup rotors on for various reasons (PCCB not really for the track at 10/10, no pad variety, easy to chip / crack, etc.).
Old 06-30-2008, 11:25 AM
zizu
zizu's Avatar
340Elise, You should try with a magnet then and confirm if the calipers are aluminum or steel/iron...
Quick Reply: Brake calipers the same for iron and PCCB?
