Electronic Nannies - PSM, etc?
I'm Still Jenny
Just looking for a quick rundown on what sort of electronic safeguards exist on a -7 GT3 and what the Porsche acronyms are. Does the car have stability management? Traction control? Electronically adjustable suspension (PASM)? If so, which of these can be defeated (ie Sport button). Can they be completely defeated or do some kick in but at a higher threshold?
Thanks a lot - I'm shopping a -7 and want to know what's up!
Still plays with cars.
The 7GT3 has PASM which can be locked into the firm position by pressing a button. It has traction control which I find a bit intolerant. TC can be locked out with a button press and once turned off, it stays off. The only other aid is ABS.
Mine has an exclusive nanny. I dont think others have this but they may. I have this high pitched voice
coming out of the passenger area. It says
SLOW DOWN!!!
NOT SO FAST!!
Do you have to go through the turns LIKE THAT!!??
When I leave the wife at home the nanny is defeated.
SLOW DOWN!!!
NOT SO FAST!!
I'm Still Jenny
SLOW DOWN!!!
NOT SO FAST!!
SLOW DOWN!!!
NOT SO FAST!!
"Slow down! I feel like I'm in a f@?!ing airplane!" Whatever that means...
SLOW DOWN!!!
NOT SO FAST!!
SLOW DOWN!!!
NOT SO FAST!!
Platinum Dealership
Charlie
also it has ABD- which as far as I know is why the rear brake pad bias is a bit more wear-prone than the 996gt3. I believe it stands for automatic braking differential and regulates the rear end while decelerating along with the Limited Slip Differential. The only way it would turn off is with sport suspension, TCS off, and Sport button pressed, but I don't think that you'll either be able to turn it off or notice it.
I'm Still Jenny
Charlie
GT3 player par excellence
SLOW DOWN!!!
NOT SO FAST!!
SLOW DOWN!!!
NOT SO FAST!!
she rode in the car a total of 9 miles and never set foot in it again.
I'm Still Jenny
Some technical explanation here chaps from the 997 GT3 Porsche Product Info Book :
http://i167.photobucket.com/albums/u...59/GT3Info.jpg
Cheers
Cheers
