Spanner Tool To Adjust Ride Height
I did a quick search on this and found nothing. Have any of you adjusted the ride height of your GT3 yourselves? If so, where did you get the spanner wrench to adjust the locking rings on the threaded perches?
When I bought a set of Ohlin's for my Elise, they came with the spanner tools. I do not see them in my tool kit or anywhere else.
I will have the dealer do an alignment and corner balance, but I want to make some minor adjustments myself before they mess with it.
I weigh about 245-250 lbs (I am getting fat, luckily I am about 6'3"), and when I get in the car, the suspension definetely sits lower on the driver's side. You can also tell on the front lip, which is scraped more on the left side due to my bulbous mass.
I want to adjust the left higher so that it is about even with me sitting in it. I did this with my father on my Elise and it worked really well.
So who can point me in the right direction to get these tools?
Thanks in advance,
Stephen
Thanks in advance,
Stephen
Look on page 2 of the racing forum. Larry posted this over there.....
IIRC it was a standard set of spring perch wrenches. This is one from OG Racing, but there are plenty of other ones available. BTW, you will need two.
That is what we planning on doing, but I still would like to have the tools. As long as they are not $500.00 for the set, then I would like to buy them.
Thank you for the offer though, that is very kind and generous!
I don't know if it is, but you do need two of them since the two rings are tightened against each other. I believe on the GT3, the two rings have different grooves cut into each one. I need to look at them again tonight.
Yes you need two cause the top one locks against the bottom one. If you want to lower the car for instance, you need one wrench to hold the top ring still and with the second wrench, break free the bottom ring by unscrewing it.
Martin
IMO, attempting to adjust the ride height yourself will lead to unintended changes in corner balance, geometry, etc...and will inevitably lead to a messed setup.
Have a professional with precision alignment & scales do the job. A little knowledge is a dangerous thing...and don't ask me how I know.
Hi Martin,
Did you get my PM? Since you have the 2, I would love to have them. And as I wrote in the PM, I will certainly pay for shipping (I have a FedEx account), but I will also give you something for the 2 tools. Just let me know what you want.
Thanks so much,
Stephen
