GT3 player par excellence Lifetime Rennlist Member
Originally Posted by 996toomey
What kind of booster seat is that?
Thanks.
recaro.
they have several, but this is the one that covers the largest range of age group. it's adjustable, the seat back grows with kid and can also be widened.
Originally Posted by peloton
How did your RS do with the 92db limit at Laguna? Are you running stock RS exhaust?
yes, stock RS exhaust. just short shift right after T5 and move way left.
i also stuff foam into air box.
i dont use turn down anymore, useless.
if i use foam and lift and move off line, i am 91.8db, sunny day.
of course.... at the 2nd to last lap, i went full bore, WOT on line, 1:40. i have done 1:39 before.
then the next lap... meatballed
245 R888 front
305 RA1 shaved to 4/32
get your car to christian g. at carlsen. he has some vacuum line technique to cure that prob. johannes van overbeek was there in a street RS. before he dumped me in 6-7 turns, he was WOT up the hill and no sound issues. christian did the vacuum trick on that car.
Originally Posted by NJ-GT
John,
When we met at Laguna, you were running 1:41.0 on the 996 GT3, almost getting to the 1:40.x.
So, you're about 1 second faster on the 997 RS, using similar tires.
What kind of lap times was Overbeek running?
since i dont use the RS as much this year, it's not set up as nicely as the 6. it pushes badly at T2 and T11. it should be more than just 1 second faster than 6.
i would say JVoB was 1:38 or 1:39. he's on 19" R888.
jeff r was on hooser, 4:1, consistant 1:38 lap after lap.... either he or his car is on drugs
