997 GT2/GT3 Forum 2005-2012
MPSC 265 front, 315 Rear, great fit.
Old 03-14-2008, 11:18 PM
str8ner
str8ner's Avatar
Default MPSC 265 front, 315 Rear, great fit.
I finally tried the 265 in the front. Despite previous threads they fit great. Makes the car feel great. As far as I can tell this is my favorite set up. Hoosier might slightly be better but definitely not as lasting.
Give them a try.
Stephan
Old 03-14-2008, 11:20 PM
str8ner
str8ner's Avatar
By the way, thanks to John from CCW for letting me try them. These were ran on his C14 rims with -2 degrees of camber in the front.
Old 03-14-2008, 11:38 PM
340Elise
340Elise's Avatar
I also have the C-14's and I assume the ones you are talking about are 18". Do you know what the width of the wheels were; 9" front 12" rear??? Also, what were the aspect ratios of the tires?
Thanks,
Stephen
Old 03-15-2008, 01:41 AM
Kevinlpl
Kevinlpl's Avatar
Yes more details please, Size and offsets of wheels. Size and aspect ratios on tires.
Did you move the tire through the entire travel and with the wheel turned each way?
Old 03-15-2008, 03:40 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,663 Likes on 2,330 Posts
Give them a try.
Stephan
265.35.18?
do you know if they are bigger than R888 of the same size?
Old 03-15-2008, 08:03 AM
str8ner
str8ner's Avatar
Wheels are the ones John has been making for all the 997 GT3. You can call him for offsets, !2", 9".
Tires are 265x35x18, Diameter 25"2, 315x30x18 25"5.
I just verified these on tire rack. Unfortunately they are in back order!
Old 03-15-2008, 08:04 AM
str8ner
str8ner's Avatar
No rubbing anywhere. Put shoe polish inside and out. Totally clear in town and on the track.
frederickcook87 (10-01-2022)
Old 03-17-2008, 01:30 AM
Jon70
Jon70's Avatar
Do you need to have at least 2 degrees of neg camber to clear?
Old 03-17-2008, 02:02 AM
jenk12m
jenk12m's Avatar
stephan, were you at VIR this weekend...if so, how did the tires hold up??
Old 03-17-2008, 09:02 AM
str8ner
str8ner's Avatar
I have 2 degrees of camber but I do not thing you need it. The tire is no where near rubbing on the outside. More camber could be an issue as it is close on the inside.
I was at VIR this week-end. Great week-end. Both my wife and I were driving. About 7 hours of track time. Running about 2min11 second a lap. Car has no mod. Lots of traffic.
Tires are showing no signs of wear!
Old 03-17-2008, 10:44 AM
Erik
Erik's Avatar
Wow, 265's, I'm just now getting ready to try 255's R888's for the first time, and I'm nervous about those. Is your car lowered at all ?. My car is lowered to the lowest/within spec setting that the car allows, and when I'm looking at the 245's up front I'm already getting nernous.
I'm not worried about the 315's in the rear, there is plenty of room there. I also run the C14's CCW's. Mooty, are you running 255's on the RS already ?. Is your car lowered ?
Old 03-17-2008, 02:32 PM
jenk12m
jenk12m's Avatar
ok, i thought that was you next to rmag in the paddock. glad to hear you had a great time. i was there in a silver 997gt3 and had a blast for my 1st time being at VIR
Old 03-17-2008, 05:04 PM
Rickard 993 Turbo
Rickard 993 Turbo's Avatar
SAme as i have
Perfect if you ask me
Old 03-25-2008, 11:28 PM
scss98
scss98's Avatar
what tire pressures are you running hot? front and back? These are the real MPSCs, not the Porsche NO specs, correct? Other than camber, is your car stock?
Old 03-26-2008, 01:05 AM
str8ner
str8ner's Avatar
33-34 FRONT, 35-36 REAR HOT. Camber -2 front and back. These are real MPSC.
Quick Reply: MPSC 265 front, 315 Rear, great fit.
