GT3 RS Decal and clear bra
Quick question to the RS owners. Does your rear fender rock guard sticker go over or under the GT3 RS sticker? It is usually body color, so for it to go over, it would have to be clear, right? Or is it right on the edge so it doe not cross?
Next question, for you RS owners. Did any of you do a clear bra material on your doors? If so, then did you have it go right over the GT3 RS decal? I know that some also did a full rear fender wrap, I believe; same question for you.
I am asking because I have clear bra rocker piece that swoops up to the rear fender; I took the stock fender piece off because of this. I also have a door guard that goes up about 1/4 to 1/3 of the door from the bottom. So if I do a special side decal on my car, then I need to know if I am going to put the decal over my existing clear bra, or take it off and put new pieces on. I personally think that once I do a decal, I can get rid of the clear bra piece on the door.
As for the one on the rocker that swoops up the front of the rear fender; I could just cut out the area where the decal will go. I think that would be the cleanest.
OK, thanks for the help, I have the solution I want. Sometimes you just have to talk (or write) about it and you end up answering your own questions.
You guys are the best; I love you all!
There is on my orange RS desk top that I downloaded from Porsche.com, North America. You can actually see the faint outline of the rock guard. In this pic I filled in the approximate area of where the line shows, but I cannot see the bottom of it:
I was pretty sure there wasn't one on it!
To be certain, I got out of the chair, looked at the car, ran my hand over the paintwork... and there is no rear fender rock protection!
i made a custom piece of 3M ppf that goes all the way down the lower rocker panel and all the way up the rear quarter panel. i then placed the stripe graphic over it. The stripe comes off w/o issues as I have replaced it a few times changing the design. the oem clear piece is yellowish and I would recommend you replace it with a custom piece before putting on your stripes.
GT3 player par excellence
CORRECT. there's clr film from factory only on GT3 and NOT on RS.
Thanks! That is interesting since the fender flairs on the RS are even more pronounced and more prone to damage.
I guess the decal is part of the reason, and they figure that RS owners are smart enough to do what they want in terms of paint protection.
I will not use the decal as paint protection; however, I will remove the paint protection on the lower 1/4 of my doors since I really don't think it is neccesary anyway. I will leave the rocker and fender guards and put the decal over it.
Thanks for the advice carreraing.
Stephen
Stephen
There was a white GT3RS without decals at Downtown Porsche in Toronto when I was picking my car up; it had the fender protection so it appears that decals = no protection.
Basic Sponsor
I've got the clear film right over the decal for protection. With so much track use, it was better for me to cover it up, even over the decal. I'll deal with taking it off when the time comes. Looks great and protects very well.
![](https://rennlist.com/forums/signaturepics/sigpic53041_8.gif)
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
The majority of RS owners that I know (including mine) has the 3M over the decal. It works great. Just make sure you do it before any road/track acivity. I have two friends that did it after a couple weeks and you can never make it perfect again.
