Will 997 GT3 production end soon?
#33
I was hoping that then next GT3 would not be out for a while so that our cars hold their value for a while. I am not worried, but it would be nice. But if they announce a new a better GT3 in two months, then I will be slightly annoyed.
It should come at the earliest in spring of '09 as a 2001 model, not in February like Mr. MK1GT3 claims and has a deposit for.
#34
Exactly, that would make more sense. What was the timeline for 996GT3 Mk1>Mk2? Do you have some specific production date ranges for the two models?
#36
Keep in mind, the mk2 just increase engine to 3.8 DFI and LED's stuff, so I don't think that take so much time for Porsche.
Nowadays, Porsche make changes very quick, there is no timescale and so call history to track.
#37
#38
I doubt it. You push a button and it's off. It's not like PSM significantly alters the driving experience.
#39
agreed.... no way in the near term
#41
#42
DFI makes sense since it's already on the Cayennes. I doubted that they would switch over to a 3.8 anytime soon. Otherwise, they would have done the GT2 in 3.8 since it's a new model or waited until next year to release the GT3 in a 3.8 and blow the automotive world away. The current 3.8 is not a split case and will require a lot of burn in time to get it to the reliability of the 3.6.
The HP increase comes directly from the use of DFI and maybe some ECU tweaks to take advantage. MkII will probably have a slight facelift in the rear lights and bumpers
I would also say the MkII will be at least MY2010 model if you were to follow the path of the 996 MkI and MKIIs.
#43
They gonna add DFI and increase around 20HP and that's it.
I believe DFI increases torque by about 8-10%, certainly in the midrange, and hopefully at the top too. So I think a 3.6 DFI GT3 should see a peak torque of 320+ lb-ft, and peak power of 440+ hp. It should feel noticeably beefier at all revs compared with the current non-DFI engine.
And I'm thinking the 998 will be a flat-8.
#44
To increase power of the GT3 engine, the internals need to be light rather than strong. That's because it produces way less torque than the turbo, but needs to rev much higher. So it may be that the GT3 engine is easier to enlarge than the TT engine. The RSR shows that it can be done.
