Which Seats to install in 997 GT3 ??
#46
GT3 player par excellence
if you have a harness bar, yes, you can use the harness, but imo, it's not very safe and i see no reason against the installation of a roll bar. you can ge the factory RS bar and stay OEM.
#47
the 996 schroth belts will fit either the 996 or 997 but you *DO* need a bar in the back to mount the shoulder straps too ...
#49
if your dont have a harness or a roll bar then what are you tying the shoulder straps to?
Definitely a harness bar is needed at minimum.
#50
well, yes, you can use harness bar to secure the harness using euro club sport GT3 seats. but you really should use a roll bar. it's much safer and you can still stuff soft luggage in the back.
#51
anyone want to swap out a set of XL CGT seats for my RS seats?
#53
i have 6gt3 seat on pass side and recardo pro racer hans xl on my side. way cheaper than 7gt3 seats.
LOL, you go drive some more before you talk![order](https://rennlist.com/forums/graemlins/order.gif)
i am at 15600, and i have only drive the car 3x from nov to dec as i have been working pretty much non stock so i can not work when 2008 season starts.
#58
They had to be fab'ed. The bar was modified (shortened) to clear the sun roof properly too. Then painted cobalt blue to match my wheels and stripe on the car.
#59
jim, nice install.
if i may make an suggestion, get a pari of split collar rings and push the shoulder strap right against each other. that way they are less likely to fall off your HANS (which you should be wearing).
