What size Hoosiers?
What front tire size is better for the 997 GT3/RS on 18" wheels:
245/40-18 or 245/35-18?
I have tried the 245/40-18 on my "old" 997 GT3 and it seemed to be fine. But it seems like most people are saying to use the 245/35-18 size.
What is the consensus here based on real world experience?
Thanks.
Thanks.
Okay, but the difference in size is:
245/35 = 24.4" tall
315/30 = 25.6" tall
Difference of 1.2"
Ratio of 1 to 1.04 ??
245/40 = 25.3" tall
315/30 = 25.6" tall
Difference of 0.3"
Ratio of 1 to 1.01 ??
Stock MPSC:
235/35-19 = 25.5" tall
305/30-19 = 26.3" tall
Difference of 0.8"
Ratio of 1 to 1.03 ??
Either way the difference is not exact right?
So is one really better than the other?
I just ordered a set of 245/40 so I hope it doesn't matter.
Thanks for the help.
245/35 = 24.4" tall
315/30 = 25.6" tall
Difference of 1.2"
245/40 = 25.3" tall
315/30 = 25.6" tall
Difference of 0.3"
Stock MPSC:
Difference of 0.8"
Would using the 245/40 actually change the brake bias slightly - more rear?
The 245/40 would be rotating less than the 245/35 so would this make the ABS think the rear needs to slow down more?
Does that make any sense?
Basic Sponsor
Preferably a D cup. But a full C will do.
![](https://rennlist.com/forums/signaturepics/sigpic53041_8.gif)
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
Matt,
You should use the 245/35R18. I use a 285/30R18 instead of the 275/35R18 for the same reasons. The turn in is crisp with the lower profile tire, and the braking is more linear.
The 245/35R18 -315/30R18 combination keeps a similar ratio to the stock 997 GT3 sizes, but the car height decreases without affecting the stock suspension geometry. Assuming the same compound and construction as the stock tires, your lap times will be faster (lower center of gravity). However, the R6 are faster tires than the MPSC, so you should see even faster lap times.
A good source if you can find them are Hoosier VRL 305 scrubs. Find a dealer that does track support and they might have a pile of tires used in Viper qualifying laps. I pick up the 305/30/18 VRL's which are the same as R6's, and have the exact same height as the 315/30/18. They will usually sell for perhaps $70 ea and have near full tread
Matt,
By the way, if you can get a 285 in the front what are you using in the rear? What kind of tires?
