997 GT2/GT3 Forum 2005-2012
997 GT3 Oil Temp
Old 08-16-2011, 01:33 AM
Snowboarder54
Snowboarder54's Avatar
Originally Posted by Aerokitted
I've been running in this range, but it has only been in the mid 70s today.
I drive my 3 very hard every time I leave the driveway, I have never had it go over 250 and only close, 240-245 on 100 degrees plus days! And I have the SW 3.9 conversion. It's usually 205-210 normal hwy driving! High revs and low speeds, 2nd and 3rd gear driving causes temp to creep up, not enough air! I'm running Mobil 1 5-40 and change oil every 3-4K.
Old 08-16-2011, 01:46 AM
Aerokitted
Aerokitted's Avatar
Yes, at the time of this pic, I was running it in 1st, 2nd gear higher revs on city roads in brief spurts here and there. Good point.
Old 08-16-2011, 02:00 AM
BBMGT3
BBMGT3's Avatar
Originally Posted by Andrew D.
As the weather has gotten hotter, I've noticed that my oil temperature has been running between 225 and 250 degrees. Actually, after driving for awhile, most of the time it's closer to 250. (I've been using Mobil 1 - 0W/40). Is this normal for the GT3?
If you are hitting 250 on track, I'd say normal, nothing to worry about.
If you are hitting 250 on the road, then you probably have a problem somewhere.
Old 08-16-2011, 08:55 AM
almeena58
almeena58's Avatar
During the summer when Oil temp close to 250 the water temp will increase dramatically to the warning area but the Oil temp never goes above 250 at least in my 2010 GT3,
when the water temp reached close to MAX then warning will be displayed and the engine blower will fail. this happened to me many timed during hot summer and in jammed traffic
Old 08-16-2011, 09:26 AM
delanobe
delanobe's Avatar
I'm a bit surprised reading this oil temp discussion?
My car never exceeds 90°C, not even on a hot day racing in Francorchamps.
Regards
Old 08-16-2011, 09:45 AM
almeena58
almeena58's Avatar
with +50 Celsius temp and slow driving believe me the car will be cooked by the engine
Old 08-16-2011, 09:54 AM
delanobe
delanobe's Avatar
Even with 38°C the car is fine but I can imagine that 50°C is a different story
Old 08-16-2011, 10:37 AM
rlips
rlips's Avatar
'11 GT3. Runs around 220 on the road. On the track, hot (100f) day, I see 245 running hard. Stop and go traffic in high heat also can get me up to 240+. Never seen 250, with over 5k track miles so far.
Old 08-16-2011, 11:44 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,629 Likes on 756 Posts
Same here, it's usually 80-90F here and humid. The car can take it better then I can ;-)
Old 08-16-2011, 12:14 PM
eab3@bellsouth.net
eab3@bellsouth.net's Avatar
Default oil temp gauge
It appears 996 has a battery/voltmeter in the left instrument pod and the 997 has an oil temperature gauge.
Old 08-16-2011, 05:33 PM
ChrisF
ChrisF's Avatar
On the street 200-215; on a very high speed track this weekend (AAA Roval) with 90+ ambient temps, it barely grazed 225.
Old 08-17-2011, 06:11 AM
ir_fuel
ir_fuel's Avatar
Regards
Then you should drive faster
On track mine also goes up to 100-110 degrees Celcius. A lot depends on the track. Slower tracks make the car heat up more because there is less coooling (saw 115 degrees C last monday, 23 degrees C outside temperature and slow technical racetrack).
Old 08-17-2011, 06:21 AM
delanobe
delanobe's Avatar
I'm still learning to drive the GT3 so I'm sure my slow driving has something to do with it
Old 08-17-2011, 09:58 AM
jbryan
jbryan's Avatar
Oklahoma City, OAT 110, Oil 200 - 220, Water 175.
Quick Reply: 997 GT3 Oil Temp
