Front clearance on GT3, rs and TT and GT2?
Originally Posted by h-bo
gt2 - hopefully no worse than 997 gt3.
thank you for the information!
Originally Posted by jhbrennan
To get the entire picture though, you also have to look at the approach angles. Even though the TT has more ground clearance than the GT, it's as likely (if not more) to scrape the front becasue of approach angle.
TT approach angle 7.9º
JH.. true, but I think that the distance from the contact point to the front lip is the same, therefore if the only variable is the clearance then lower=more scraping
MJ.. cool thank you!
