GT3/RS Sport Exhaust switch defeat??
#31
Thanks again Larry for your help. Made it so easy for me.
#32
Can someone explain to me exactly what the sport button does with regards to the exhaust.
On my car, with the sport button off, the valve opens if I exceed around 4k rpm.
If I put the sport button on, it sounds as if the valves are open all the time. Even at idle.
So does unplugging the vacuum line do anything further than what can be accomplished by pushing the sport button?
#34
More info : http://www.carnewal-europe.com/cpx_p97084.htm
http://www.youtube.com/watch?v=z1V9lW1CW-4
#35
Neat product. But the sport button works just fine for me. And even when you don't hit the button, the valves open anyway when you start flogging the car. The car gets loud whether you like it or not
#36
I just unplugged the vacuum lines at the exhaust flappers and installed a plug, then tied them out of the way. i want the sound all the time. i still use the sport button just in case it does something else, ie, ecu mapping change.
