F430 in flames
Originally Posted by Alan Smithee
It can happen to late-model Porsches, too. I watched a Cayman shoot out a huge plume of flame recently. Appeared to be an oil line bursting onto hot brakes. Surprising to me that nothing ignited.
Technical Guru
Originally Posted by silverboy
are there known cases for newer 911's to experience the same fate?
Originally Posted by tdf360
Wow, that's a stretch. Why so defensive? Porsche is a great car, you don't have to concoct silly reasons like this one to remain loyal to the marque. How different do you think the percentages are between Porsche and Ferrari in things like this?
Gary
Gary
But I'm more interested in your question about the percentages between P and F.
Data is hard to come by, all we have is the internet.
I've been a regular reader of wreckedexotics dot com for 3 or 4 years now. It is no suprise at all to see pictures of burned or still-burning exotic Italian sports cars, every other month or so. Usually they are sitting on the side of the road with no crash damage and the accompanying story (which yes I know cannot be trusted for specifics) tells a similar tale to the original poster's friend - driving along then flames shoot out.
New, near new, older, and sadly very old Ferraris and Lamborghinis all *seem* to have far higher rates of spontaneous combustion than any other make - judging by internet pictures alone.
Porsches, on the other hand, usually make it to these sites with crash damage, often severe yet preserving the passenger compartment. The leading cause is (suprise) driver error. I can't recall the last burned Porsche I've seen on wreckedexotics.
Internet only - I suspect we'd have a lot of insurance company database exploration in order to get real usable numbers.
I can tell you that over on the 928 board here, we have had a few cars damaged and destroyed due to fire. Usually old and brittle fuel lines in the engine compartment are the culprit, but once in a while the aging mass of electrical relays and wiring will short and spark. Lack of maintenance can quickly lead to lack of car for these aging machines, but the problem is not traceable to any design/build flaws.
- Josh
Originally Posted by JasonAndreas
.... The model 996TT and GT2 were recalled because a bolt attaching a high-pressure line to the power steering unit would come loose and allow power-steering fluid (pentosin) to leak onto the exhaust and burn the car to ground.
The leaking (ps) fluid on a car there (GT3) could have had disasterous results. Luckily for the individual involved there was a very competent and senior Porsche mechanic on hand to rescue the day.
Originally Posted by JEC_31
You are correct that it's silly to base maque loyalty on a single incident.
Gary
I've heard that the connection where the fuel line meets the rail, has "come loose" on a few. The factory marks the connection with a line of paint that is easily visible. Every time I get in the car, I glance to make sure that the top and bottom of the "painted" line are still lined up.
video taken by my friend that morning.
you can just barely glimpse my car during the opening title page (white GT3 ahead of the ill fated Ferrari)
http://www.youtube.com/watch?v=0vTc-kKEnUU
Porsche has not always been so intelligent with regards to design. Those familiar with the 944/968 line should be very familiar with the "Car-B-Que" nickname. The steel fuel lines route into the engine bay directly over the exhaust manifold, where they enter the fuel rail via an 90 deg elbow made of rubber. It is no wonder one of the first "mods" us 944 guys do is to put a Halon bottle in the car
Hi,
The Porsche agent sells their P97 GT3 for US$239K. I got mine slightly used from the USA for US$195K. So you guys are very lucky in the US. I have no idea how much the F430 goes for.
Hi,
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
