Fuel Filling Saga......
Last Sat I had PDI (handoff) done and took delivery.
Went to the gas station with my salesman to filler-up, and 1/2 tank was all that could be put in.
I take the car and later in the day I try again and manage to get to 3/4, click click. WTF
Sunday, drove around a bit then before returning home figure I'd try again..Click, Click.
Monday before the Hangover Rally, what the heck give it a try...Click, Click manage to stuff 0.75 gal in.
In CA we have very bulky Vapor Recovery nozzles that once in a while can be problematic.
Bright and early Tues...off to the dealer...where they do every electronic test, all pass.
Research TSB's and some 997C4's had a fuel filling problem which called for a replacement of a pipe..
A part was ordered and delivered from the distribution center by 2pm....wrong part.
The tech worked valiantly to find the problem and seemed to do somthing that allowed a full load of fuel to be loaded.
An email was sent to Atlanta Tues afternoon with a description of what was done and for advice as how to proceed. Too late for an answer, so the car spent the night in the shop.
Late today I got the car back, however the car will be going back as soon as a part arrives from Germany to perform a service action simlar to the 4S fueling problem.
Sorta sucks after 2.5 days and 200mi of ownership.![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Has anyone else had any fuel filling issues with their GT3??
me
also, let the tank get down to 50miles before empty, then stopped and put 5 gallons in before i hit the dyno and when the car restart it still said 50 miles before empty
did the 2 pull 93 octane dyno session
then put in by external gas tank 5 gallons of 109 (tank now had 5 + 5 = 10 gallons + whatever the computer said would get me 50 miles
then, after the dyno session, stopped and put in 6 gallons of 89 to bring the octane level down and this time the tank filled up ????
bah humbug! you'll have the gt3 back in no time and will be ready to go!
Bri, migrated to 19" Porsche Carrera Classic 5 spokes with new rubber. You'll be ashamed to hear that i'm taking the pcar to Lucent to have Techart Springs installed, tomorrow.
i figured that was better than 20" go for show!
i feel the heat coming
I've having similar issues with my Targa 4S. I am trying different stations, and some are better than others. It still takes me several times to get it full, and I don't think i ever get it all the way full.
I have had this problem on a number of Porsches here in LA. I just pull back on the spring on the nozzle and fill it up to the top. I dread going to the dealer here after having a couple of cars banged up.
that is the proceedure that the Tech Gurus in Atlanta/Germany recommended to proform when new fill pipe arives from Germany.
A good (bad) sign...
Another GT3 owner from Huntington Beach, CA (Beverly Hills delivery) posted over on Rennteam of a similar refusal to fuel issue...could not fuel above 3/4 tank...click click.
I'm not alone!!!
Anyone else here experience any short fueling problems (anything less than FULL)
I'm not alone!!!
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
This is a repost but since I live on the border between CA and NV it does represent a bit of interesting empirical data... when I fill in CA I get the same problem. Usually it gets to 3/4's full and click. When I fill in NV I don't have the problem.
The area of NV that I live in does not have ANY vapor boot on the pump nozzel and I have no trouble filling up. The areas of CA that I occassionally fill in have the spring loaded boot on the pump nozzel.
Back in the fall, as an experiment, I filled in CA while holding the vapor boot off the tank fill neck with my left hand ( I was wearing gloves ) and the tank filled full.
CA vapor boot + Porsche fill neck = too tight a seal that trips the fill switch on the gas pump nozzel.
Edit - I have just been reminded that I also experience the fill problem on the '06 Cayenne turbo S... when filling in CA. Something about the fill necks on Porsche MY '06 and later.
