NEED TPMS Help.
So. Your module was deactivated, the normal process is you code out the module and deactivate it in the gateway, then unplug the unit. Did you do the reverse? The coder should see the module. You will want to check the sensors were pre coded by the supplier.
At some point I’ll turn mine back on
Pouring rain today so waiting for a dry day to tackle the job.
