997 GT2/GT3 Forum 2005-2012
rebuild shocks?
Old 03-02-2024, 12:44 PM
Vocan
Vocan's Avatar
Originally Posted by my first 911
How do you deal with PASM?
Ohlins sells delete boxes that plug in to the wires so you don't get the warning but it's cheaper to just code it out with PIWIS, Durametric Pro, etc.
I actually haven't seen the warning pop up on my car yet but I'm sure it will come at some point, at which point I'll just code it off.
Edit: Once I removed DSC and re-installed the stock PASM box the error popped up. Easily coded it off with PIWIS.
Old 03-02-2024, 05:49 PM
SiNzz
SiNzz's Avatar
Did you guys also replace your camber plates at the same time? If so, any recommendations?
Old 03-02-2024, 05:58 PM
Vocan
Vocan's Avatar
Yes, I went with new OEM front and rear top mounts. The OEM fronts are already monoballs and allow for more than enough camber for my needs. I believe they're very similar if not identical to the Cup part but someone can correct me if that's incorrect. You could do aftermarket monoball rear top mounts if you wanted but OEM should be good for most use cases and fairly durable.
SiNzz (03-03-2024)
Old 03-03-2024, 08:53 PM
SiNzz
SiNzz's Avatar
Looks like I may be able to get cup fronts from a friend for cheap, so thanks for that input!
Old 03-05-2024, 10:22 PM
Mvez
Mvez's Avatar
Bilstein is soon relaunching their recently discontinued "Clubsport" line as a new double adjustable EVO-R line for the Cups and GT3/RS. Nicer build quality, and alot cooler features than the predecessor line. Some really, really cool stuff too like inverted rear shocks for cars like BMW
s etc. etc. Something you would never get from the smaller shock companies. They told me the testing for the various Cup car kits is completing soon, and the street car kits should follow soon after.
They've already started releasing EVO-R for other Porsche models, and alot of other cars, so they are definitely coming down the line.
Definitely a kit to keep an eye on. Will slot in between a Ohlins R&T and a TTX. I personally like my re-valved Clubsports on my GT4/M3 just as much as the TTX on my other cars. They are great on track, and a bombproof setup that lasts years and years between rebuilds for street or track use.
If you're not in a huge hurry, and want an inverted front strut package, with double adjustability, this would be my choice. I love the R&T's, but once you get used to double adjustability, it's just too hard to ever go back to singles.
The following 2 users liked this post by Mvez:
f50nut (03-05-2024), MJFDDS (03-06-2024)
Old 03-05-2024, 11:11 PM
f50nut
f50nut's Avatar
Very interesting. Do you happen to know if they’ll offer a PASM option?
Old 03-06-2024, 10:33 AM
Mvez
Mvez's Avatar
Bilstein already offers a PASM/Damptronic direct replacement. You can probably find it cheaper through PSI.
They are the authorized seller and servicer for Bilstein now.
Coil Over Suspension Kit 997.1 GT2 / GT3 / GT3 RS - RWD - BILSTEIN - B16 Damptronic - For PASM (fvd.net)
Old 03-06-2024, 02:47 PM
craina
craina's Avatar
Do you know if Bilstein will offer a clubsport kit for the 996 gt3?
Old 03-06-2024, 04:26 PM
Mvez
Mvez's Avatar
That I don't know. They currently offer a PSS9 single adjustable kit, but not sure if they feel there is enough demand for a new EVO-R kit for the 996 chassis. I don't believe there was ever a Clubsport kit for the 996.
I can ask my contact and see what they say.
craina (03-08-2024)
Old 03-06-2024, 04:40 PM
craina
craina's Avatar
I currently have the Ohlins R+T on my car, about 10k miles on those now. I think I am ready for something DA and have heard great things about the Bilstein Clubsport kit.
Old 03-06-2024, 04:52 PM
f50nut
f50nut's Avatar
I'm running that setup currently but wouldn't mind some additional adjustability. It's a bit harsher than the stock setup.
Old 03-08-2024, 09:06 AM
my first 911
my first 911's Avatar
Does anyone have part numbers for the camber plates?
Old 03-08-2024, 07:10 PM
bmw_e30
bmw_e30's Avatar
Originally Posted by Spyerx
I don't think you're getting anything killer for shocks at $2k.
good shocks are about $4-10k for a set at $2k you can have a nice steak dinner with the wife and another couple maybe
Old 03-11-2024, 02:56 PM
globed
globed's Avatar
When l last checked with Bilstein Technical Center UK just a few years back, they were offering a rebuild service on factory GT3 shocks… can’t recall the price, but was quite reasonable. The contact number I had was: +44 116 289 8345. It would be a pain for most to deal with shipping, but an option perhaps.
I’ve recently moved to US with my 997.2 GT3… in retrospect, I should have had them rebuilt while I was living there 😤
Quick Reply: rebuild shocks?
