Money2536's Grey Black 997.2 GT3 RS Journal
#46
Wow those belts look great. I need to do that to mine.
Do you have any tips on cleaning or rehabing the deviated stitching? Mine is red and the drivers door needs some love its either faded or dirty/improperly cleaned.
Money2536 (12-12-2022)
#48
Porsche likes to delaminate so I don't know many 997 owners besides collectors that are replacing with genuine carbon atm regardless of price... DBcarbon has a lifetime warranty and looks great
The following 3 users liked this post by Wonderdan:
#49
https://www.tpmsbargains.com/PORSCHE...PMS-s/1371.htm
#50
And to think you could have got a set of sensors for $120. Same brand and if you wanted OE RDE048 that would have been $275. Suncoast is a nice one stop shop but their prices are outrageous.
#51
Also, did you never find your centerlock tool? Or was it straight up missing? I haven't touched mine for a while but I THOUGHT it was below the bottom floor of the frunk last time I looked.
#52
In the GT3 its usually in the left bottom cubby behind a fabric panel. However (I have yet to field test this beyond my ownership-2) but its my understanding the centerlock tool is only included with the Sport Chrono optioned cars.... otherwise its a false panel in the same spot.
onelove (12-14-2022)
#53
Received 2,397 Likes
#54
My .2 GT3 didn’t have sport chrono and still had the centerlock tool in the trunk. The tool should be located behind the door at the bottom of the trunk on the passenger’s side (or on the left relative to this picture) like Dan stated. The other side should contain tire goo that is used to seal tire punctures, but this should never be used as it’s not a great way to fix this issue and the goo has very likely aged out.
#55
Matt - in your latest video you mentioned the concern you had with your windshield. The passenger side sticking up is not normal as you called out. Likely was replaced at some point. Saint Gobain Sekurit is the OEM windshield. See pic below to see if it's a genuine windshield or not. If it's genuine it'll have the triangle Porsche logo on top as shown below. Otherwise, it'll just say Saint Gobain Sekurit. The OEM windshield is cheaper than the genuine as you'd expect.
#56
The part number for the e-brake is 997-424-980-94-A15 and was $1,041 when I replaced mine in July 2021. Order it now, if you want it — mine had to come from Germany and took months.
#57
Matt the front axle lift issue you mentioned in your latest video is most likely a faulty pressure switch or relay based on the things you described. Not a super expensive fix unlike how it used to be in the past (replacing the entire system) before this issue was further investigated finding the fault to be only minor. Keep in mind this was Porsche’s first attempt at a front axle lift so the system wasn’t perfect. Here is the link to a really good thread and video on this common issue.
https://rennlist.com/forums/997-gt2-...-cpo-pcna.html
#58
Needsdecaf (12-12-2022)
#59
LOMartin (12-13-2022)
