Engine drop to do coolant lines. What else "while I'm in there?"
Okay...
Found an indie shop that has certified Porsche mechanics and bought the parts today:
Thanks everyone for the push down the proverbial slope!
- Coolant hose set with water pump, thermostat, and coolant expansion tank. Got the elbows from @Wonderdan earlier, thank you!
- LWFW and 4.0 clutch with RS pulley
- Guard LSD
- Rear toe kit and rear links
- DSC controller
Okay...
- Guard LSD
- DSC controller
Burren (01-04-2023)
Hi Julien,
You have an excellent list so far. To clarify, do you plan to go with the Dundon (made by ATI) dampener? Also be sure your shop uses the Sharkwerks elbows. When I had the lines/engine drop done on my car I also had plugs, coils, fuel filter, drive belt, front main seal and rear main seal. Many will say that if the seals aren't leaking, don't do them, but I had them done anyway. I also had all fluids flushed at the same time, but that is sort of implied with the work you're having done since you'll be doing your LSD and the coolant will all be coming out of the car during the pinning process. I think power steering fluid will need to be replaced also when the engine is dropped. So really it just leaves engine oil. You may also want to consider doing fresh engine mounts, if it was me I'd probably just go with stock mounts.
Best of luck, glad you're already getting the maintenance done, that's a great way to start off ownership.
Reach out with questions. Happy to help.
fayraree (01-14-2023)
You’re correct! I have a .1 GT3 which has the external serviceable fuel filter, in the engine bay. The .2 GT3 has the fuel filter integrated into the fuel pump and thus, is not serviceable. Here’s the .2 GT3 maintenance schedule and I don’t see the filter as being listed.
