What other models share the GT3RS rear body?
I know that the GT3RS uses the wider AWD body. What other models share the same rear body? Would 997.1 and 997.2 be the same? Your help is appreciated.
Aside from the dimensions, I'm not sure the RS body/shell is the same as any other wide-body variant. May just be lore, but I've heard there were production variations that distinguish them (RS) from the others (C4/C4S/GTS/Turbos), even though they (RS) started from the same platform (as the C4/C4S/GTS/Turbos). If that is the type of information that the OP is after, maybe someone here knows? If not, apologies for the distraction.
GT3dailydriver (10-28-2021)
are you repairing a wreck and planning to re-shell the car? or doing a rear-clip repair? I would think that the easiest way to know the answer is to look up the body shell part #s for the various non turbo wide body cars in the parts diagram, although they are all NLA now. I believe only the front tub is available for purchase as a single piece.
You can cut the front fenders and fit cup flares, otherwise the front fender trim is just glued on the rs. Rear rs wing will fit any body, with a decklid. Rear bumpers and side skirts are different
