Rusting Rotors After Wash
Hey guys. One of the best things I did for my RS was to get softer pads. Not only do I not anymore of the annoying squeak, but the brake dust is barely noticeable now. I don't track it, so no need for the aggressive brakes. BUT, every time I wash this beauty, the rotors rust almost immediately. Today, I had the "bright" idea to take if for a drive right after washing...take it up to 100 for short period and clean them off while drying them out. The result was rusty water all over the freshly washed rims and rear of the car. I don't recall having this issue with the other ones I had. They look stock. Any ideas?
Just curious, which pads are you running? Eventually I'd like to switch to a softer compound, potentially, to avoid the added brake dust.
As far as rusty rotors, you have a couple of options, but unfortunately you're always going to be dealing with some of the situation you describe. You can use a product such as Hydes Serum Rust Stopper. This maybe helps 30-60%. But it definitely doesn't completely solve the rusting issue. I also don't like having another product that I have to buy, use, possibly have hazardous to my health, another product to possibly damage something in the braking system, etc.
https://www.obsessedgarage.com/produ...rust-inhibitor
My preferred method is wash wheels, wash car, give one more rinse to everything including rotors. I typically will then blow dry the wheels to get the heavy water off. Drive down street, apply brakes (carefully as you don't have much bite with the water on the rotors), then when you come back you're going to have the rust inside the barrels. I then do a final wipe, with gloves on, to the inside of the barrels to try and remove the rust. This takes a bit of time, but is the best I have found, unfortunately. I then will finish wiping down the body. You may get a bit of dust on it from your short drive, but with a drying aid such as Griots Best of Show detail spray, that should help prevent/minimize any scratching. Obviously ceramics would prevent this too, but that's a $10-20k solution compared to this which is 5-10 mins of extra time each time I wash, which is 2x a month during summer.
gman3280 (08-23-2021)
HB651F624 and HB483B635. They've been great. I can feel the difference in bite. Not a big deal for me though on the street.
Thanks for the info on pads! Hopefully others chime in with suggestions, but what I posted above is the best I have found.
After I wash the car, i use my craftsman 250 mph electric leaf blower and dry everything, including wheels. By the time I'm done they're dry and I drive the car. Otherwise if it's parked for long they stick, and the car certainly won't even roll
I also use the leaf blower on the engine area, and belt to dry everything
Some good ideas. I like the leaf blower. They do get an enormous amount of rust. When I let the dry by themselves, it puts orange dust all over the wheels on the first drive.
How old are the rotors ?
BTW, any advice on dash treatments and rubber molding areas? I've heard some things will actually make it crack and dry. Never used to worry about stuff like that. But, it is a 14-year old car.
Robocop305 (08-21-2021)
Definitely use a battery powered blower to dry your car. I use a Milwaukee m18. Great piece of equipment for drying, blowing off dust and blowing out the garage. Even blow the dust out of the interior!
Yes! That would be better than drying with microfiber. It has ceramic so should blow right off along with helping with the rotors.
After I had my 993 ceramic coated my guy said do not dry with microfiber. I bought the blower and was amazed! Open all doors and water just falls away with blower assist.
Warning, when they transitioned from 1Z Einszett to Nextzett they changed the formula of their products including cockpit premium. Some say the new formula smells like urinal cakes. While I agree there is a similarity in scent, it goes away quickly and I have yet to find a better product after 8+ years.
For seals on doors, Nextzett Gumifledge is great.
I prefer the handheld blower like you have. Eventually I will step up from my Ryobi one to an Ego like the 650cfm
