Smog Check and EVoms Tune
#31
California is not a state that wants you to drive a tuned GT car, much less anything else with an internal combustion engine.
You are a bad person for wanting to do that, and you will have to fight for it. This is just like Calguns.
Will be interesting to see how this whole thing evolves.
#32
things like this just reset the sensors so it takes a while to get them back to normal… nothing unethical about getting lower MPG. Every time someone putts their foot in it or goes over 55 they are voluntarily doing the same thing.
#33
The smog tech is savvy (and caring - he'll warn you if he sees any of the monitors reporting "not ready" prior to running the test). In this case, he specifically asked about whether the EVAP monitor had been coded out, because of whatever he saw when he scanned the car prior to starting the test, and he only observed that after I flashed back to original, i.e. the second time I went that day after failing the first time. I interpreted that to mean something different than the usual "not ready" after disconnecting the battery or resetting fault codes, because he very specifically looks for that and advises folks to go for a drive to remedy.
Looking at your other thread I, don’t want to be oversimplify but your readout looks text book drive cycle. It says you tried to get them to ready by driving a lot. If your not intentionally trying to set them with an extremely strict drive cycle it can take thousands of miles of regular driving.. once it it took 3500 of mixed miles for everything to set for me.
Also, what I see is more than just the EVAP monitor reporting missing - it's nearly all the other interesting ones (including "catalyst") - I don't know why the tech didn't mention those, too. Knowing little to nothing about what "tunes" are capable of doing beyond changing data tables such as fuel maps, I took it as possible that they might contain code to (for example) modify the way the emissions monitors report status over OBDII but not how the emissions systems function internally.
#34
Hmm 996 don’t have EGR valves so I see no issue… if you were missing all those others the report would have also shown that… it shows them working.
did you maybe flash back to your stock tune but didn’t uninstall the evom OS? I’ve done that before unintentionally and only figured it out when I hooked up my Porsche diag software.
#35
#36
I’m not sure since I don’t have Evoms, but I assumed it worked like the Cobb. Where I had a screen with multiple tunes to switch to OR un-install cobb accessport all together.
#37
I'm not sure what to make of it either. Durametric shows everything ready (even after doing something that would normally unready things, like clearing faults). The other apps I have clearly show things listed here like "catalyst" as missing/not available. The section these appear on this sheet is "visual inspection" so I am guessing that's why they're all passing (nothing visually noted about them). I did fail at this same shop last December for aftermarket DVs, so I know he's looking (I finally got around to going back to OE DVs this past week, which is what triggered me to take it back in).
I did not know that was an option. The handset I have (looks like this link) only offers switching back to "original" or (once one has done that) selecting from one of two EVOMS tune files - X50 (which I have optioned on the car) and some other (which I assumed was a non-X50 default tune). The shop where I purchased this didn't mention any steps beyond that.
#38
If we all go at the same time, I also have to smog next year, maybe it will trick the system into thinking a tuned car is the stock form.
#40
That's one concern I had where if I fail with the EVOMS tune if it will flag the car to then have to go to a state ref instead of being able to re-smog with the stock tune at the normal station.
#41
