e88 fitment issue - help
Hi all,
I recently purchased a set of e88s, they look great but unfortunately have an issue with front wheels fitment. The inner edge of the rim is rubbing against the spring - 2nd coil up from the bottom. The wheels were advertised as Front-18x9 et50 Rear-18x12 et63.5. What are possible reasons for the rub or next steps should I consider - get an alignment/check suspension, get 3 or 5mm spacers? Wheels are clearly not spec'd as advertised, contact seller...? I have 07 GT3. Thanks in advance.
Upload
Upload
What is the number on the wheel center of the fronts and rears?
997 GT3 non Center-lock
Front Uses 0288274 center / 1.0 outer / 8.0 inner ET + 50.0
Rear Opt 1 Uses 0288108 center / 2.5 outer / 9.5 inner ET + 64 w/o factory 5mm spacer
That's the front right yes? Does the front left also rub? If not, I'd get an alignment first.
What's your current alignment?
Few questions:
1. Are you running a spacer on the front? If "Yes", did you put it on after you found out it was rubbing?
2. Is your center front or back mount.
3. Can we assume that your tire is also rubbing as your third and fourth coil up from bottom is clean?
Then all the other questions the previous members stated.
Hi JFL503,
There is some fitment information here on BBS rims: https://rennlist.com/forums/996-gt2-...t-numbers.html
Perhaps something there can help.
Ray
Ray
